I went out with a cup of coffee this morning and decided to look under my hood. When I did I noticed oil on the underside of the hood. It appears to have been sprayed. There was oil arounnd the tube going in to EGR cooler and on the oil filter cap. I cranked it and let it run for thirty minutes and didnt notice any leaks. I had the coolant flushed this week also. Any ideas? The Truck is running good with no issues. I'm not running any tunes (unless po did) but it does have an after market intake. Stock gauges seem fine ( know they suck). I am a very novice diesel guy.
I think you need to clean the oil from the engine and take it for a drive and periodicly check under the hood for leaks. One thing you can do is to remove the oil filter cap and check the oring for any damage.
