I've been having problems with my truck again and I feel like its a starter. It seems to have good batteries with charge but when I try to turn over it gives it like two slow cranks then clicks. would this just be a starter that is starting to go bad. also i noticed right before i shut it off that it was not running at normal battery voltage while i was driving, would a starter do that.
The thing that i thought was weird was that when i was driving with the lights on it said that the batteries were a lot less but when i went to start it the batteries looked fine? Any help would be very much appreciated.
alright i am going to check all that out now thanks for the ideas i'll let you all know if the selenoid connection was the problem. it shouldn't be the batteries or alt. because they are all new, i got them all last week. Also, thanks for everyones input on here you all have gotten me through some sticky situations.
Or with the batteries also, just because they are new doesn't mean they are 100%. They could have a defect from the factory. Been there...dealt with that!!
Well its not moving. My truck is a 01 but i don't know if its early or later. I have it hooked up to another truck right now and when i try to start it it turns but then it quickly dies out and doesn't start up
