Speedometer needle removal?
Old Oct 9, 2010 | 10:31 AM
lgwilson's Avatar
lgwilson
All you white face gauge dudes/dudettes chime in here. I'm painting my gauges today and when I got to my speedometer I realized I need to remove the face so I can paint it without painting the odo and the trip odo numbers. To get the face off, I have to remove the needle. How do you do this? Or did any of you just tape off the openings? I am actually thinking about laying a strip of masking tape behind the face to block the opening so I won't have to remove the needle. I'll wait a few for any wisdom before I do anything here. Thanks in advance.
Old Oct 9, 2010 | 10:34 AM
ctubutis's Avatar
ctubutis
It pulls straight off. I took pix of to where the needle was pointing so I could re-install it
in approximately the same location.
Old Oct 9, 2010 | 12:35 PM
lgwilson's Avatar
lgwilson
Really? I pulled and what I thought was pretty hard too, but I didn't want to break the damn thing so I stopped. Oh well, I ended up undoing the screws behind the faceplate and that left me enough room to slip a piece of tape behind the windows so I could paint without FUBAR'ing the odo's.
I knew you'd chime in if you saw my thread ctubutis and glad you did. Thanks again.
Old Oct 9, 2010 | 09:00 PM
ctubutis's Avatar
ctubutis
Originally Posted by lgwilson
Really?
Yeah, man....
Old Oct 10, 2010 | 02:06 PM
lgwilson's Avatar
lgwilson
I guess I should have pulled harder, but I was really torquing on it and didn't want to break it. I'll know next time.
Old Dec 27, 2014 | 01:35 AM
Jasonf150's Avatar
Jasonf150
right tool for the job.
If you read through this, and can't get the pictures to load... like me. What I did was put a napkin under a fork (yes, the kind from the silverware drawer) and then used it as a very miniature pry bar.
Note: if you've taken all of your needles off of your other gauges, and realize they are very thin metal, followed by noticing your speedo needle looks slightly bent. DON'T BEND THE SPEEDO NEEDLE!!!! That one is plastic. Hope this helps someone.
Old Dec 27, 2014 | 09:32 AM
ctubutis's Avatar
ctubutis
I fixed the pictures.......
Sycostang67
'80-'86 HOWTO's
181
Dec 5, 2019 02:56 AM
Shiloh51933
Feb 3, 2017 05:06 PM
88_F0RD
15
Dec 4, 2016 12:45 PM
93nighthawk
Aerostar
39
Sep 23, 2015 08:55 PM
Rusty_S
59
Jun 28, 2015 05:47 PM
