Aerostar Ford Aerostar
transmission question
Old Feb 23, 2003 | 01:03 PM
dougas's Avatar
dougas
Did the 4.0 L come out with a transmission without overdrive? I'm thinking of getting rid of my overdrive because it is cheaper to rebuild the transmissions.
Old Feb 24, 2003 | 12:26 AM
Racerguy's Avatar
Racerguy
The 4.0L only came with the A4LD automatic overdrive transmission.
Old Feb 24, 2003 | 12:18 PM
dougas's Avatar
dougas
Is there any way I can use the bell housing for a different transmission? Is there any way I can cross over? Any suggestions would be appreciated.
1990 4.0 L
Old Feb 24, 2003 | 02:27 PM
Racerguy's Avatar
Racerguy
Just guessing but I think that a C5 transmission out of an early Ranger would probably bolt up to the engine.
Really though the A4LD isnt a bad transmission after updates are done on it.
Hopefully someone here will have some more insight into it.
Opera House Works do you have any good ideas?
Old Feb 25, 2003 | 04:16 PM
Opera House Works's Avatar
Opera House Works
It is often very easy and cheap to fix. When you remove the bellhousing, the OD clutch and planetary gear are the first two assemblies. Planetaries are only about $50 and the OD star washer is $8. If it is just a daily driver, you could replace these parts in about an hour with no special tools and leave the rest of the transmission alone. Except for the low/reverse servo which is always bad to some degree and only requires the removal of four bolts. That seems easier than adapting another transmission. The A4LD is not a great transmission but they are easy and very cheap to work on. Basic gasket kit is $30 and manual $16.
wilburn
1997 - 2003 F150
18
Mar 12, 2019 11:42 PM
tex4431
Oct 17, 2016 11:08 AM
fifty-two_f1
WTB - Parts & other
Dec 27, 2015 10:23 PM
mikey89014
Nov 1, 2009 01:21 AM
DadzzTazzDullie
Mar 4, 2008 06:25 AM
