Tire swap will 5 hole rims from 96 Bronoco Fit 2000 Exp Sport 2 door 4WD
if its the smaller Bronco II - probalby has 4.5 inch bolt pattern like the EXP. If its the bigger Bronco, that is a 1/2 ton truck wheel and is 5.5 inch. Measure the distance center to center between two studs and see if it is the same... then check the hole diameter that fits over the axle.
Ford 2 - Vehicle Bolt Pattern Reference
