F350 PROBLEMS
Old Oct 8, 2010 | 12:44 PM
RORY19-79's Avatar
RORY19-79
F350 PROBLEMS
HI I HAVE A 94 F350 THAT ORIGINALLY HAD A 460 5 SPEED 2WD CREW CAB NOW I WANT TO CHANGE TO A 351 5 SPEED 4WD WHAT DO I HAVE TO TO TO MAKE IT WORK AS IN COMPUTER WIRING?? ANY IDEAS LET ME KNOW
Old Oct 8, 2010 | 05:59 PM
rla2005's Avatar
rla2005
Please turn off the cap lock key. If the 351 is already EFI you can swap in the motor and transmission with relative ease. You will need an engine computer (PCM) from a 351, the pinouts are basically the same. Use this for reference: Ford Fuel Injection Truck Pinouts
Old Oct 14, 2010 | 09:19 AM
RORY19-79's Avatar
RORY19-79
SO WHAT YEAR PCM SHOULD I BE USING TO MAKE THIS RUN RIGHT??
Old Oct 14, 2010 | 10:40 AM
polarismuddman's Avatar
polarismuddman
Any year before 96 and an SD ECM. So an 87-95 Speed Density ECM.
Old Oct 14, 2010 | 10:50 AM
RORY19-79's Avatar
RORY19-79
SO THE PCM IS IT GONNA MATTER IF ITS FROM A STICK OR AUTO , 351 OR 302?? OR ARE THEY PRETTY MUCH THE SAME????
Old Oct 14, 2010 | 11:18 AM
polarismuddman
Manual and auto and 302 and 351 all use different fuel curves, if you need to you can get away with running whatever computer you can get your hands on but your truck won't run as efficiently.
Old Oct 14, 2010 | 11:21 AM
RORY19-79's Avatar
RORY19-79
SO WHAT YOU SAYIN MY BEST BET WOULD FIND A 94 PCM THAT WAS A STICK AND A 351
Old Oct 14, 2010 | 11:23 AM
polarismuddman
Yes, but it doesn't HAVE to be a 94 EEC.....any year before 96 that is a speed density computer with a 351 and stick....you'll be lookin at alot of F250's and F350's to find it.
Old Oct 14, 2010 | 11:29 AM
RORY19-79's Avatar
RORY19-79
THANKS FOR ALL THE INFO AFTER I FIND THAT ILL HAVE TO TACKLE WIRE HARNESS'S
Old Oct 14, 2010 | 03:30 PM
Diesel_Brad's Avatar
Diesel_Brad
Please turn off your cap lock it is annoying as hell.It means you are yelling.
You will also need a 351 transmission as well, the big block and small block have different bellhousings.
You will, need 351 engine perches as well. The 460 ones will not work
Old Oct 14, 2010 | 03:39 PM
Big-old-460's Avatar
Big-old-460
I agree with brad all i can do at this point is LOL Love the CAPS LOCK HUH
j/k
