Head gasket
Old Oct 8, 2010 | 07:08 AM
got2befast's Avatar
got2befast
Head gasket
Does anyone have instructions on how to remove heads and reassembl with cab on? I am needing to get my truck tore down to the heads this weekend and then back together by next thursday. Thanks for the great info.
Old Oct 8, 2010 | 01:14 PM
Zmann's Avatar
Zmann
https://www.ford-trucks.com/forums/8...-hvac-box.html
Old Oct 8, 2010 | 07:30 PM
cheezit's Avatar
cheezit
when doing this job remeber ford pays us 15 hours to do it. try and beat that time.
its just like doing heads on any other engine.
Old Oct 8, 2010 | 09:50 PM
got2befast's Avatar
got2befast
Are the arp studs reusable. And what is the torque specs on them.
Old Oct 8, 2010 | 09:51 PM
cheezit's Avatar
cheezit
yes and 210 ft lbs. do in incrments of 70 ftlbs at a time
Old Oct 8, 2010 | 10:12 PM
got2befast's Avatar
got2befast
ok where can I get lube. And the forum I went to says they pulled the heads without taking the hvac box out has this been done with studs installed.
Old Oct 8, 2010 | 10:14 PM
cheezit's Avatar
cheezit
yes it can be done. its a pain.
I dont know maybe a vender that sells the studs. its not a motorcraft item
Old Oct 8, 2010 | 10:18 PM
got2befast's Avatar
got2befast
OK well do i need to pull the studs all the way out then run a tap through and reinstll the stud
cheezit's Avatar
cheezit
the threads most be cleand of all debris
Old Oct 8, 2010 | 10:19 PM
got2befast's Avatar
got2befast
I know all of this seems common sense but I only want to do this once so I want to make sure its done right
Old Oct 8, 2010 | 10:21 PM
cheezit's Avatar
cheezit
its common to me. you are not me and you dont do this every day. I do. No worries I dont mind at all. really.
keep one thing in mind I am a dealer tech and deal mostly with factory issue. so on some things I am somewhat limited with awnswes and knowldge.
Old Oct 8, 2010 | 10:27 PM
got2befast's Avatar
got2befast
Thanks so much I got the truck tore down to the intake tonight so tomorrow start getting down to the heads have to have them off by Monday so they are done by Munday night if everything checks out good.
Old Oct 8, 2010 | 10:32 PM
cheezit's Avatar
cheezit
its not gonna be fun.
you should really rebuild the oil cooler at the same time if you have not planed to.
Old Oct 8, 2010 | 10:35 PM
Zmann's Avatar
Zmann
save that for twosday ,,,lol
Old Oct 8, 2010 | 10:44 PM
got2befast's Avatar
got2befast
I had just deleted my egr, new oil cooler, new hpop, new ipr, and new lpop, but deleting my egr did not correct my puking so now to the heads, plus have to put dummy plugs cause I drove my truck to town and back and it died on me so everyone thinks its the dummy plugs so I will fix that also. And hopefully that fixes everything cause I have to pull my 17,000 lbs camper 2400 miles in two weeks.
