No fuel cap??
Old Oct 10, 2010 | 09:51 AM
  #31
n5926g's Avatar
n5926g
My 07 had a locking gas cap that the P/O evidently put on it.It was a PITA especially having to use your keys(paint scratch) to open it. I bought one of the "door" type from rockauto,and couldnt be happier.
Was initially kinda worried about the CEL coming on due to the new cap,but it has worked flawlessly.
Old Oct 10, 2010 | 04:22 PM
  #32
Evan92's Avatar
Evan92
You could have just left the gas cap key in the console or cupholder or whatever and just grabbed it when you needed to put gas in the truck. No need to carry it around with you.
Old Oct 10, 2010 | 04:50 PM
  #33
n5926g's Avatar
n5926g
That would have been fine for me,but the wife..........................................
Old Oct 10, 2010 | 05:42 PM
  #34
fordpstroke11's Avatar
fordpstroke11
Don't worry. Nothing gets into mine on my 2010 F-150. It seals fine and makes filling up at the station a little quicker.
Old Oct 10, 2010 | 06:07 PM
  #35
rlh68050's Avatar
rlh68050
Originally Posted by superrangerman2002
Says the kettle?
So if I drive 20K mi down the highway and don't have a problem.....that means there's no problem? But if someone drives six miles down a dirt road and does have a problem on a new truck with less than 500 mi, I should tell them they are full of it?
Yeah I can see the problem with the fuel door...It's a flimsy piece of plastic that doesn't create a good seal to the flimsy seal on the body. It moves with temperature variation, has a CTE, and isn't locked or drawn against the body. Wind currents from road speed can also make it move as wells as body flex. Oh, did I mention that every thing about the door / neck assembly doesn't allow for adjustment to bandaid said design short commings?
Please enlighten me on the proper adjustment that I should perform on this.
Roll of duct tape?
Please enlighten me also about the door being the only seal.....You must mean the seal on the trap door of the fuel neck. Yep there is a seal there.
I wonder what is going to happen to all of the dust on the trap door as I put the fuel nozzle into the tank? Better not spill fuel on the trap door as you pull out the nozzel. Good thing there is a fuel filter still....
I wouldn't be so ticked about this if I didn't have so much experince on the engineering end of recalls and the amount of money it wastes.
I find it very disapointing that alot engineering thought went into the filler neck (as much as I hate it, it appears to be sound minus the entry of dust particles.), and virtually none into the door it self.
If more thought was put into the whole assembly I would not have issue with from a design and real world function point of view.
I didn't know South Dakota was the center of the automotive engineering universe. If you say it's true, it must be!!!
Old Jan 8, 2012 | 08:41 AM
  #36
MacTaggart's Avatar
MacTaggart
If my dealership elects to not replace my fuel neck, I will provide a writeup on how to do it yourself in the event that out of warranty trucks need this replacement, or for those that would like to do it.
I'd love to see that write-up.
Old Jan 8, 2012 | 10:15 AM
  #37
rgmiller32's Avatar
rgmiller32
3 f150's so far with this system and no problems. Had 48k on the highest mileage one and that was driven out the in the Dakota, Kansas way for most the time I had it. Also 2 Escapes so far with no issues. Vs 1 Dodge and 1 Chevy with gas cap issues and fill neck replacements to pass inspection.
carbon coupe
Aug 18, 2014 12:35 PM
cdmm151
Ford In-Vehicle Tech
Aug 8, 2013 11:47 AM
Dearborn-1979-mudder
Apr 13, 2009 09:30 PM
FS-150
2004 - 2008 F150
Mar 27, 2005 10:58 PM
jacrol
Jun 26, 2003 02:27 PM
