Cold Weather Sputter
Old Oct 7, 2010 | 12:00 PM
BobbyB's Avatar
BobbyB
I have a 2004 F-250 that has started to sputter some when the temperature reaches 40 degrees. Its not a dead miss, just a sputter for maybe 10 seconds. Last winter I noticed that when I turned the key on to cycle the glow plugs and injectors, the sound started to change. Previously I could here the fuel pump running, the glow plug relay would kick on and off and I could here a loud buzzing, arcing sound which I attributed to the injectors cycling. The buzzing, arcing sound started to get weaker over time until it was totally gone. As the sound weakened, the sputtering started during cold weather starts. I checked the FICM voltage, it stays around 47.8 to 47.9 volts and it has relatively new Interstate batteries. It started around the same time that I replaced the IPR valve. I can't remember if I disconnected both batteries when I replaced the valve, but I think I did. I've re-checked connections at the FICM. Any suggestions?
Old Oct 7, 2010 | 06:59 PM
Maxium4x4's Avatar
Maxium4x4
Injector sticking maybe, how many miles on the truck? Had the EGR out lately?
Old Oct 8, 2010 | 07:43 AM
BobbyB's Avatar
BobbyB
140,000 miles. The EGR is disconnected. Its not a dead miss just a rough idle for 5-10 seconds. The think that puzzles me is that I don't hear the buzzing anymore. I'm going to retest the FICM. I was doing the test by myself and did not have any way to load test it.
6ohguy
May 6, 2015 01:41 AM
rcCraig
Mar 19, 2011 06:37 AM
buckweet1980
Feb 5, 2011 11:10 AM
518landscape
Dec 22, 2010 07:25 PM
dirtleg
Nov 6, 2010 02:05 PM
