door pin removal
Old Oct 6, 2010 | 10:06 PM
agronomistont's Avatar
agronomistont
door pin removal
do i need a special tool to get the pins out of my 51 hindges or just a bigger hammer
Old Oct 7, 2010 | 12:00 AM
Old F1's Avatar
Old F1
They pound out from the bottom (don’t ask me how I know), take the doors off first by removing the hinge bolts if you can, makes it much easier.
Many previous posts about this.
I believe because you don’t have 25 posts yet you can not use the search feature (?) but there is a work around available. Go to Google and use the Advanced Search and enter your search item and under “Search within a site or domain” enter 1948 - 1960 F1, F100 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums
I did a search for "remove door pins” but they have a shelf life and will self-destruct and disappear in 4 hours 18 minutes and 22 seconds.
Ford Truck Enthusiasts Forums - Search Results
Old Oct 7, 2010 | 07:14 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Yeah, "if" you can get the door off by removing the hinge screws you can turn it upside down and pound them out much easier.
That's how I got mine out but if you can't get the hinge screws out, keep pounding and use lots of PB Blaster. They are stubborn but eventually will come out...
Old Oct 7, 2010 | 09:24 AM
CharlieLed's Avatar
CharlieLed
Heat and a BFH
Old Oct 7, 2010 | 09:38 AM
ZOOT's Avatar
ZOOT
Thought I saw a "special tool" for hinge removing. Looks like a special size c clamp. I think I saw it in Dennis Carpenter's catalogue. I never removed mine, so I'll go with "heat and BFH"
Old Oct 7, 2010 | 09:57 AM
51PanelMan's Avatar
51PanelMan
Don't spend money on the special tool. It'll break before you even try to use it. A few have tried that took without any success. Heat, PB Blaster, a punch and a BFH is all the tools needed.
Old Oct 7, 2010 | 10:20 AM
Old F1's Avatar
Old F1
When they say heat, they mean Oxy acetylene heat ………either on the pins or hinge screws and pins. And maybe an air chisel with the punch bit and hearing protection?
(….did you read the search?)
Old Oct 7, 2010 | 12:43 PM
GreatNorthWoods
Those "special hinge pin removal tools" are worthless!
Old Oct 7, 2010 | 03:54 PM
FLUSHED UP's Avatar
FLUSHED UP
I got mine out finally by heating the hlnge cherry red and a punch with a BFH Thats after soaking it for days and useing an impact hammer punch. If you do remove the door, drill a pilot hole first so you can realine the door when putting it back together. Wish I did
Old Oct 7, 2010 | 08:13 PM
agronomistont
thanks for the help. inot sure where you are suggesting to drill the holes
Old Oct 7, 2010 | 10:45 PM
Old F1's Avatar
Old F1
Just a small hole from the outside of the flat on the inside part of the hinge into the cab door jam just as a reference as to where the doors were mounted.
………did your search results help?
Old Oct 8, 2010 | 10:08 AM
leverhead's Avatar
leverhead
I would definitely take them off before beating on them.....easier on the cab/door pillars. Soak them for a day or 2 with PB blaster then use a punch and a vise to hammer them out. Something that works well for me is a concrete anchor installation tool (really a big punch with a larger diameter head than a typical punch). Get a couple and you can grind the ends down to the diameter you need to just fit the hole. Works well for leaf spring pin removal also. Regards.
72CC428
23
Nov 26, 2017 08:49 AM
carrcreekcaller
Aug 26, 2015 03:10 PM
Osiyo59
Jan 28, 2015 12:23 AM
captntim
All Things Towing
Feb 15, 2002 11:16 AM
art015
Jan 15, 2001 09:03 AM
