Keep Getting P0102 Code
Old Oct 13, 2010 | 05:40 PM
brandon82's Avatar
brandon82
sorry man i cant help you there. i wish i could. let me know what fixes the truck tho. its either the MAF or pcm, possibly wiring. for your sake i hope its not a pcm. good luck with it
Old Oct 13, 2010 | 05:49 PM
AndeyHall's Avatar
AndeyHall
It was the PCM. Now I'm having the problem with the truck not boosting at all. Like normal driving with tunes I use to run about 7-8 pounds cruising, now I'm only running like 2-3 while slightly accelerating.
Old Oct 14, 2010 | 06:12 PM
brandon82's Avatar
brandon82
so it has no power now, did it throw any different codes?
Old Oct 14, 2010 | 06:17 PM
AndeyHall's Avatar
AndeyHall
I'm not sure if the turbo had to go through a relearning process with the new PCM but it seems to be gradually getting better. The turbo whistle gets louder and louder every few times I drive it. And the boost and power seems to be picking up a little. But I'm really not sure what the deal is. No codes yet though.
Old Oct 14, 2010 | 06:37 PM
brandon82's Avatar
brandon82
i would keep driving it,youre prob right with the turbo relearn.
Old Oct 14, 2010 | 06:46 PM
AndeyHall's Avatar
AndeyHall
I think I figured out my problem. He just said that it probably wouldn't relearn with no EGR valve, but I actually do have an EGR valve and I just plugged it back in today to get rid of the EGR codes it was giving and that was the start of when I started noticing it driving better.
Old Oct 14, 2010 | 07:34 PM
brandon82's Avatar
brandon82
ah ha. hope it gets better with driving it and now that the egr is plugged in you should be good
Old Oct 14, 2010 | 09:22 PM
AndeyHall's Avatar
AndeyHall
Yeah the guy at my shop told me I could unplug it with the delete but the guy that wrote my tunes told me not to because then my cooling fan wouldn't work. So that's why I plugged it up this morning. I didn't know it had anything to do with the turbo.
Old Oct 15, 2010 | 05:28 PM
brandon82's Avatar
brandon82
everything is connected in way way or another ha ha
Old Oct 15, 2010 | 05:33 PM
AndeyHall's Avatar
AndeyHall
Yeah I've noticed that. It makes diagnosing problems so freakin annoying. A blown out brake light probably causes injector problems...who knows haha.
Old Oct 15, 2010 | 05:54 PM
brandon82's Avatar
brandon82
just makes everything for techs harder in a way
Old Jul 14, 2012 | 06:49 PM
WarrChild's Avatar
WarrChild
I am having his same issue on my 04 F350. I tried the pin test and got 12.7 on pins.2&3 but I didn't get anything on pins 3&4. New here but spend a lot of time over at powerstroke.org. Thank for the help.
Old Jul 14, 2012 | 07:33 PM
  #28
BLADE35's Avatar
BLADE35
Souinds like you have the early MAF sensor that also has IAT sensor within it
so not all the wire are for MAF
1 wire should be V-Ref 5volt for the IAT sensor
MAF should have a 12 volt power and Ground with signal circuit
What is the Exact code you pull????????
Old Jul 14, 2012 | 07:38 PM
  #29
BLADE35's Avatar
BLADE35
heres the operating value per Ford
MAF 0 1.44 2.65 0.5 - 4.75 VOLT Mass Air Flow
so that goes like this
KOEO=0
Low Idel=1.44volt
High Idel=2.65volt
operating Range=0.5-4.75volt
Do you have a ScanGaugeII????????????
Old Jul 15, 2012 | 02:12 PM
  #30
WarrChild's Avatar
WarrChild
I have a CTS. The code I'm getting is p0102. I think there are 6 pins maybe 5 im not looking at it right this second.
