66 trans brackets
Old Oct 6, 2010 | 04:30 PM
jeffm66's Avatar
jeffm66
66 trans brackets
I recently purchased F150 352 3spd w borg warner T85N/OD trans. When I got the truck home and was going over it I noticed the trans had 2-3/8x 1 1/4'' brackets,from the bottom 2 trans bolts to the crossmember. I don't know if this original or what, as the other truck with same set up doesn't have this. I thought motor trans was mounted on rubber for a reason. Mounting trans to crossmember metal to metal doesn't seem right. If the brackets aren't original some one did a good job on fab and even replaced trans bolts with studs and used nuts.?
