Sponsored by: Real Truck
Heater does not work
Old Oct 6, 2010 | 11:56 AM
AKtruck's Avatar
AKtruck
I jumped in my 01 f 350, and the blower for the heater/ac does not turn on. I could feel heat bleeding out the dash as the truck warmed up, but the fan will not kick in. I tried all different positions of the dial from ac to defrost and no dice, the fan will not turn on. Any ideas on where to start? Which fuse/fuses should i look at, and if need be if the motor easy to replace? Thanks for the help!
Old Oct 6, 2010 | 11:58 AM
AKtruck's Avatar
AKtruck
Clairify...
What I mean to say is the fan motor easy to replace? Thanks....getting cold here!
Old Oct 7, 2010 | 08:03 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Thread moved to the Superduty forum, because this might help someone else, and get more answers all at the same time
Old Oct 7, 2010 | 10:29 AM
dchamberlain's Avatar
dchamberlain
First think I think, is to download the owner's manual for your year, if you don't already have it. Then look up the fuses section, find the heater fan fuse and check it. You can download the owner's manual here...
https://www.flmowner.com/servlet/Con...ionalEventPage
If the fuse is OK, then the next thing would be the heater fan relay. That may be listed in the owner's manual, I'm not sure and I don't think it is in mine. But you could look. If it's not, you're going to need someone with a 1999 service manual.
GuyGene
1997 - 2003 F150
May 15, 2012 04:31 PM
thomm
Oct 31, 2011 03:00 PM
KrenzyRyan
Jul 8, 2011 03:12 PM
tim nick
Escape & Escape Hybrid
May 25, 2011 10:34 PM
tsheriff
Dec 26, 2002 11:27 AM
