heads install ??
Old Oct 6, 2010 | 10:13 AM
ozblitz's Avatar
ozblitz
heads install ??
Is there a steel dowel pin or thick washer that goes on a 351w before mounting the heads? I don't recall putting this on when I torqed the heads down and read a book that mentioned these dowel pin washers. Do I need them or are they there just to hold the heads in place for you to install the head bolts??
please help.
Old Oct 8, 2010 | 09:45 AM
mark a.'s Avatar
mark a.
There are 2 hollow dowl pins that go in the 2 bottom, outer bolt holes and they do need to be in there, or you will end up with a head gasket leak.
