Block heater plug in
Old Oct 8, 2010 | 02:16 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
.....and that's less than 10 amps if you have 115 volts for your service.
Old Oct 8, 2010 | 02:24 PM
BarnieTrk's Avatar
BarnieTrk
Yep, I'd be using a 110/115V service.
So sounds like this weather-proof timer should work then, since it's rated for 1200 Watts / 15 amps.
Intermatic 24 Hour Plug-In Landscape Electromechanical 1200W 15A Outdoor Timer
Cool -- Thanks, Bud!
Old Oct 8, 2010 | 03:05 PM
Cowboy65's Avatar
Cowboy65
Originally Posted by BarnieTrk
I'm thinking the block heater may use somewhere in the 700-950 watts / 15-20 amp range.
700 - 950 watts would equate to around 6 to 8A.
The block heater is around 1100 to 1200 watts which is around 10A.
My plan is to use a timer so it doesn't run all night long. I'd set the timer so it turns the block heater power on, say, 3 to 4 hours before I plan to start the 6.0L diesel on those less than 25*F mornings.
This is a good idea. Keeping the block heater plugged-up for an extended period of time is a waste of money.
Old Oct 8, 2010 | 04:50 PM
rocky1074's Avatar
rocky1074
I have an 03 live in Florida and mine came with one. Check again It's behind the pass side tow hook..It's hard to see and it has a zip tie to keep it in place. I had a hard time finding it also. I'm sure it's there.
David Fehir
Jan 22, 2016 05:25 PM
bigcountry1009
Oct 14, 2014 10:23 PM
bcaughhorn
15
Feb 2, 2011 03:16 PM
greggara
6.7L Power Stroke Diesel
Jan 1, 2011 09:10 AM
rmosso1
Feb 11, 2008 10:24 AM
