OBDII Scanner
Old Oct 5, 2010 | 10:29 PM
timmyboy76's Avatar
timmyboy76
OBDII Scanner
It aint an AE, but does work. Fetched a code from a buddy's auto 7.3(01), but when hooked to mine, during the "live data", it'll shut it off(truck, 99.5 6spd)). Cant figure it out. No fuses..etc, popped or wrong. Any ideas?
Old Oct 5, 2010 | 10:36 PM
robles4242's Avatar
robles4242
You confuse me boy. Fetcher shuts the truck off? Dont you do it with the truck off to begin with? Or the truck shuts the scanner off?
Old Oct 5, 2010 | 10:41 PM
timmyboy76's Avatar
timmyboy76
the scanner shuts the truck off, as if i turned the key off, during the "live data" scan.
Buddy's truck had the ses light on, so i hooked scanner to it, with key in "on", fetched the code(p0500), then i did the "live scan" on his truck, which you need to have truck running, during its cycle, never gave his truck a burp, hesitation..naughta, worked great, but do the "live data" to my truck, and when it does its cycle, whamo, truck dies.
Old Oct 5, 2010 | 10:43 PM
robles4242's Avatar
robles4242
I assume it worked on your truck before correctly? Is it possible you have to clear his trucks info before you can start (not too familiar there are so many different kinds that all work different)
Old Oct 5, 2010 | 10:47 PM
timmyboy76's Avatar
timmyboy76
ALWAYS killed my truck, during that cycle. So when he showed up, thought it be a good time to try ur out, see if it killed his, which it didnt.
No codes on my ride, just want it to work right. I've cleaned all the terminals, inspected the cables..etc, atta loss here. Just purchased it about 2mon ago, (the truck), and dig'n it.
Old Oct 6, 2010 | 12:30 AM
robles4242's Avatar
robles4242
Oh wow man. Thats crazy how the meter is doing that.. Tomorrow morning im sure a bunch of the smart guys will chime in and be able to give you and answer!
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
