Radiator input needed
Old Oct 5, 2010 | 08:41 PM
grams72's Avatar
grams72
Found a deal on a radiator, problem is that it does not have the internal transmission cooler so it must have been for a manual trans.
I have an automatic but I also have a huge aftermarket trans cooler in line.
Would you gurus advise using a manual rad on an automatic?
The price is 100.00 not that it would make any differance...
Old Oct 5, 2010 | 08:44 PM
greywynd's Avatar
greywynd
Some of the guys will know better than I do, but part of the function of that oil cooler being in the rad is to help get the oil up to operating temperature in colder weather. I don't know what or how it would affect things without it. If you were in a warmer climate it may not be an issue, where you are, I don't know.
Old Oct 5, 2010 | 08:48 PM
grams72's Avatar
grams72
Im in cold country ie Fargo ND / Moorhead MN however the truck will not be used much if at all in the winter months.
Old Oct 5, 2010 | 09:35 PM
charleswood6969's Avatar
charleswood6969
If you don't pull a trailer or carry huge loads, I wouldn't hesitate to use it. Especially if you can find a second transmission cooler to put in line with the one you already have, plus maybe find a cheap deep tranny oil pan for extra, extra cooling.
Old Oct 5, 2010 | 09:51 PM
grams72's Avatar
grams72
well.....would you consider 12,000 lbs a lot to pull
Looks like I should keep looking?????
Old Oct 5, 2010 | 10:09 PM
Sycostang67's Avatar
Sycostang67
I had an 85 F-250 with a 460/C6, I bypassed the rad/trans cooler and only used my A/C condenser which I converted to a transmission cooler. The transmission still reached the same operating temps it did before, it just took longer to reach them in the winter.
Old Oct 5, 2010 | 10:10 PM
charleswood6969
12,000 is onehelluva load on a IDI engine and transmission. I would find a copper radiator, OEM, and run TWO coolers, plus a deep aluminum pan. I pull a 6500 lbs camper, and that's what I did.
I really don't know how you do it with an engine rated at around 200 hp. My 6.9 is only rated 170 hp.
Old Oct 5, 2010 | 10:19 PM
Sycostang67
I'm actually surprised how easily 200hp will move 12k. I figure total weight(truck/trailer/load) on mine is about 20k at times and it moves pretty good. I laugh when I see all the dodge guys with 4-600hp to pull little trailers that weigh less than 6k.
Old Oct 5, 2010 | 11:15 PM
LCAM-01XA's Avatar
LCAM-01XA
Same here, but I did it on my IDI. Works fine, but then again my fan clutch is locked so it blows full speed all the time, which I'm sure helps a lot in an air-only cooling setup.
