Coolant Level?
Old Oct 5, 2010 | 06:47 PM
Heckler's Avatar
Heckler
Coolant Level?
I have a 2004 so no sticker but I know that the full level is now the min mark on the degas bottle, question is, is that with the motor running at normal operation temps or motor off after it's completely cooled down?
Old Oct 5, 2010 | 06:50 PM
69cj's Avatar
69cj
Motor off completely cooled is what I go by and have never had a problem.
Old Oct 5, 2010 | 06:53 PM
bpounds's Avatar
bpounds
Hot. Running or not doesn't matter.
BTW, mine has been running near the original full mark for several thousand miles now, because I inadvertently over filled it after my last flush. It has not puked a drop. I tend to think the whole overfilled thing was just a bandaide coverup when they first started having all these 6.0 issues. If your truck is in perfect condition, the coolant level will not be critical.
Old Oct 5, 2010 | 07:01 PM
69cj's Avatar
69cj
I agree with you Bill 100% but I'm going with the flow and yes I never did have a problem be4.
Old Oct 5, 2010 | 07:06 PM
bpounds's Avatar
bpounds
To clarify, your degas bottle has two marks. They were originally supposed to be FULL COLD (lower mark) and FULL HOT (upper mark).
Now, FULL HOT is the lower mark, and COLD should be somewhere below that point.
That's my understanding.
Old Oct 5, 2010 | 07:08 PM
69cj's Avatar
69cj
I use the min. level as my cold mark and no probs.
Old Oct 5, 2010 | 07:41 PM
bpounds's Avatar
bpounds
Me too. Are we just lucky? Or blessed? Super smart? Yeah, that's it. Let's go with super smart.
Old Oct 5, 2010 | 09:16 PM
Heckler's Avatar
Heckler
Thanks guys... now Im even more confused.....
Waiting for more input, then I'll go with the majority... lol
Old Oct 5, 2010 | 09:18 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
I used the min mark after flushing. Stays right about there all the time, a little lower when cold, but not much.
Old Oct 5, 2010 | 09:33 PM
Fallguy2004's Avatar
Fallguy2004
Like most others mines hovers around the MIN mark, on MIN hot and just below when cold.
Old Oct 6, 2010 | 09:25 AM
Cowboy65's Avatar
Cowboy65
The following was copied from Ford TSB 06-3-8 (Coolant Degas Bottle Overflow) which was released in Feb. 2006 and applies to the following vehicles
2003-2005 Excursion
2003-2006 F-Super Duty
2004-2006 E-Series
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]-->Prior to making any repairs verify the coolant level is not overfull. The level should be at the "MIN" line in the degas bottle at operating temperature. Overfilled coolant levels will cause coolant to vent from the degas bottle cap.
The Bricker
2015 - 2020 F150
Mar 30, 2015 05:24 AM
jaltman1984
Mar 2, 2014 01:11 PM
MJ76
Feb 13, 2014 10:55 AM
thrifty
Jan 22, 2014 08:10 PM
Filthy1955F100
Aug 21, 2013 11:15 AM
