I am at the point where I need some suggestions for a problem that has been bugging me for some time and has become a challenge. I have been getting an intermittent CEL with codes 226,212 since November 2009 on my V6 EDIS-6 4.0L OBD-1 Explorer. It seems to trigger the CEL most often when the engine rpm is greater than 1500. Also can trigger a CEL when the engine is cold after initial start. The engine runs very well, but the exhaust smells a bit rich at idle when cold. The tach's reaction to engine speed is smooth. The original ignition coil pack and original EDIS-6 module have been replaced. The engine is running smooth so I have not suspected an intermittent failure in the connection between the EDIS-6 module and the ignition coil pack. I have swapped the new and original EDIS-6 modules a couple of times. I have cleaned coil pack and EDIS-6 terminals including the wiring harness connecting terminals.
Because this problem is intermittent and the tach is smooth I have not suspected a fault in the main computer and the continuity of the wire (terminal 2) between the EDIS-6 module and the main computer. According to my electrical diagram the tach pickoff is just ahead of the main computer on the same wire from terminal #2 on the EDIS-6 module.
The most often suggested solution I have received is: Get some tape and tape over the Check Engine Light. Any and all suggestions will be greatly appreciated!!!
Thanks for your response. I'll follow up with the PCM connector asap. I don't think it has a cam sensor because it is a push rod engine. The crank sensor was replaced within the past year. I haven't suspected the crank sensor connection, because the Ignition Diagnostic Monitor (IDM) signal is on a direct line from the ICM to the PCM. Where am I wrong on that assumption?
