Doing DSII conversion....
Old Oct 5, 2010 | 11:18 AM
Arkdriver's Avatar
Arkdriver
I have a 1985 Bronco with the 4.9l I6 in it and am about to do the conversion since I can't get it going right as is (sensor problems). Anyway, i just want to make sure my shopping list is in order.
Here is what I need to do conversion right?
(all off a pre-84 I6)
-Distributor
-Ignition Coil
-Ignition Module
-Wiring Harness
-Carb off a pre-84
-Coil wire
-Wire that runs from Elec. Chock to alternator in case elec choke is working on new carb.
Am I missing anything? Thanks gang.
Old Oct 5, 2010 | 11:35 AM
JimsRebel's Avatar
JimsRebel
Your list looks good, good luck at the junk yard.
Jim
Old Oct 15, 2010 | 03:27 PM
Derrick lane's Avatar
Derrick lane
85 4wd truck doing same thing in Ar.
Trying to do the same thing to my 85 f150 4wd I6 300 are you in ar. i'm in mena ar. trying to find anything hear worth using is next to imposable. As there are no junk yards within 100 mi. Hope it all works out good for you. I'm still searching for the rite parts that work for a smog delete.
Old Oct 15, 2010 | 03:42 PM
AbandonedBronco's Avatar
AbandonedBronco
Derrick,
Your best bet may be to see if you can find someone who can send you a wiring harness, or a schematic so you can make your own. Other than that, all of the parts for the conversion can be purchased new.
Distributor: ~$50
Coil: ~$40
Ignition module: ~$40
1bbl carb: $~150 - $250
Old Oct 15, 2010 | 04:22 PM
Wyowanderer's Avatar
Wyowanderer
New wiring harnesses are available at Painless Wiring but they're not painless- last I checked, the harness was over a hundred dollars.
NAPA has all the plugs, so with the wiring harness (available at junkyardgenius.com) you can build your own.
KsCop
Nov 19, 2013 05:29 PM
Joejustatruck
Oct 24, 2012 11:49 AM
lab66
Dec 17, 2007 09:09 PM
55-willys
Jul 5, 2003 09:44 AM
gohan
All Things Towing
Jul 22, 2002 03:37 PM
