460 pistons
Old Feb 22, 2003 | 06:47 PM
hybridf250's Avatar
hybridf250
460 pistons
Does anyone make a set of pistons for a 460 that would put my compression around 10-10.5 to 1? I have 72 cc CJ heads and a 73 block. I am pulling this engine in a competition street class and right now it's a CJ top end with a cammed 70 Lincoln bottom end. I want to build a better bottom end for next year and all I can find is either 11 to 1 or 8.5 to 1. By the way I'd like to find forged full-floating ones. thanks.
Old Feb 22, 2003 | 08:38 PM
DPW's Avatar
DPW
Lightbulb 460 pistons
Contact ROSS RACING PISTONS, give them all the info, piston to deck, chamber vol. etc. if they don't have a shelf part # they will make whatever you want.
Old Feb 24, 2003 | 01:52 AM
fudds1's Avatar
fudds1
460 pistons
Ross are good pistons. Here is there phone#[310]536-0100 They are located in Calafornia. Another good piston manufacture is, J&E or Wisco. I've used them all. They all worked geat! I had J&E custom make some 557 BBF piston's, they were around $700.00. I used Wisco in my 351W around $500.00. Used Ross in a 390FE.
So that might give you an idea.
Good Luck
