stock injectors=how many miles
Good stuff guys, thanks for the inputs. Now I must show my ignorance... What exactly is the AE? Is it a stand alone OBD II reader on steroids or???? And does it come with instructions so I would know what I'm looking for and how to interpret what it is tell me? I just can't be changing parts cause the computer tells me to, I've got to know why, ya know?
I'm thinking I'll be ordering up a turbo rebuild kit and going from there. I had the turbo off last winter and installed the WW but don't recall seeing how the guts would be pulled out for a re-build, anyone have some pics? Instructions? Tips?
After that, my next plan is to pull the valve covers and check the torque on injectors etc since thats NEVER been done on this truck. From there I'll decide on injectors.
Of course all this may get put on hold if I get deployed this go around, as I'm on the short list for the sand box. Should find out soon...
Thanks for every ones input
Riffraff Diesel: AutoEnginuity
Roadside Help Network - Guides, Maintenance & Mods
Riffraff Diesel: Garrett GTP38 Journal Bearing Rebuild Kit
Welcome to BDrummonds Van Turbo Rebuild Web Page
If it is balanced before you take it apart to rebuild it will still be balanced when you reassemble it.
Isn't the compressor wheel bolted on or is it only one way with some sort of woodruff key? So how do people do it if they replace the wheel with a WW?
The compressor wheel is tapped so that it threads onto the threaded shaft. IMO since the exhaust wheel and shaft are balanced and the compressor wheel is as well when you assemble it will still be balanced.
Check with your tuner about the 140 mod. Get a tuner. Or if you want to try, get say DP-Tuner to flash your PCM. $75. If you don't like it, send the PCM back. If you like it, keep it and send him back your old one. That is what I did. I liked it after months to get the F5. Then I got the F6 which is way nicer. No R&R. Laptop and a USB cable and you can flash the chip for a "Try before you buy".
#28
visseroth
you have the mods nessisary to be able to safely add a nice chip.
I have the F6 and it rocks. Well worth the extra money to be able to try a tune, or just have an updated tune sent to you. No downtime waiting for your f5 to come back, or no waiting for your ecu to be shipped both ways and you cant even use your truck. (ive promoted the 75 dollar reflash a number of times if you just want a little better oomph and a lot better throttle responce) Call Jody and after you talk with him you will realize your missing out on something special, LOL.
I HATED my psd when I first got it, and I wanted my bb 460 back. After the 80e I was all grins. Well worth the money.
#29
Stage 3s may be a bit more than I need, but it does bring up a question. If I went with anything other than stock injectors would I have to send my DP tuner back for a re-program?
And if I went with different injectors would I then be forced into looking into a turbo upgrade? How far can a stock turbo take you?
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
#30
