2.9 V-6 Engine
Old Feb 22, 2003 | 05:55 PM
George_911's Avatar
George_911
2.9 V-6 Engine
could anbody tell me where the EGR VALVE is located on a 1987 Ford Ranger with a 2.9 engine?
Old Nov 17, 2004 | 08:07 PM
87 b2's Avatar
87 b2
EGR valve location
As your looking at the engine from the radiator end. It is on the front right hand side of the top intake manifold. Its mounted with 2 bolts on a flange. When you get it off check to see if the hole into the manifold is clogged. Mine was and caused the ERG error code.
Luck
mudslinging79
Bronco II
17
Aug 13, 2010 11:18 AM
tom3tone
1983 - 2012 Ranger & B-Series
May 25, 2007 02:00 AM
ol yeller
Aug 20, 2006 01:11 PM
devilsword
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Mar 21, 2006 09:17 PM
BroncoIIRob
Bronco II
Feb 23, 2004 04:12 AM
