The OOOHFISHALLY sanctioned NS B/S Chat thread!
Received 1,419 Likes
on
The following users liked this post:
on
If you don't see any rust it'll likely galvanized Jeff.
Post that in the 2009 - 2014 F150 forum:
https://www.ford-trucks.com/forums/forum193/
my roof is rusted in some spots and a few years ago i had screws loose sticking out . had a guy replace screws with bigger ones ,he said 2 out of 5 were stripped.
Howdy All. I’ll assume it is too Morris. It must be, I hope so anyway, I don’t want to have to deal with it. We replaced a lot screws on a shop roof years ago, and my dad had it sprayed with a silver coating. It’s still holding up. Not what it was sprayed with.
I agree, if it were me, I’d pull the box. Being a California truck should come off easy.
Received 4,245 Likes
on
on
Howdy All, Im having some issues with this new ethanol gas. Anyone else having issues? Nothing of mine is running right anymore. Apparently as of this year, all gas has ethanol in it. And increasing every year up to 15% by 2030.
Edit. Removing ethanol also reduces the octane…. I suppose I’m off to buy some premixed gas for the saws this morning. Not sure what to with the rest of the equipment..
on
hi every one ! if you have access to a engine hoist lift box ,alot easyer and you can run truck to make sure everything is ok . did you check the fuel driver !
I checked the Fuse, is good. Rained and hope dry of June will help.
It has run in Salt + 12 winters. That module is probably toast. I have
an A Frame Beam and Chain hoist in the garage there, if I need to lift
the box. Problem is the truck is out in the Drive. Problems
Started right after a Hurricane HP car wash. I see the kit adds rubber
spacers to move the modules aluminum base off the steel frame.
_______________________________________________
Edit.. You can thank Ottawa for that.
