Spread of the virus is always going to be worse in heavier populated areas but infection rates lower also because of those numbers, Alberta is worse than Ontario..
67 is in storage until spring. So, basically figuring out what to buy for it over the winter. Need to get the wiring harness for it at some point, so I can mock all that up in the cab, and add some of the lighting that I want, so I can get all the holes drilled before hand, So, that may be one thing. Otherwise, I'm on standby for the winter! I wish I had a shop!
I'm almost at a stand still on the newest project but I am waiting for my door latches to arrive so I can get them installed, after that I may pull the pickup out of the shop so I can spray the epoxy on the doors and the rest of the bodywork that's done. After that I have some work that needs done to the pickup to take care of that oil leak..
