Speedometer wont recalibrate
Old Feb 22, 2003 | 04:01 PM
2Wise4aGM's Avatar
2Wise4aGM
The speedometer on my 92 F250 wont recalibrate. It goes into calibration mode(Says I have three calibrations left), displays my current calibration number, but when I push select to change it-NOTHING. The number stays the same. Anyone have any ideas?
Thanks in advance,
Mark
Old Feb 22, 2003 | 09:11 PM
HippieCustoms's Avatar
HippieCustoms
I am assuming you are grounding the psom wire when you trying to make the ajustment....If so it should work...
Old Feb 22, 2003 | 10:00 PM
2Wise4aGM's Avatar
2Wise4aGM
Yes I am grounding that wire. I recalibrated it a few months ago when I switched to 35 in tires and it worked fine. Now I switched back to 33's and want to recalibrate it so it reads correctly. It says I have 3 calibrations left. I dont understand why it wont work.
Old Feb 22, 2003 | 10:05 PM
HippieCustoms
I had a prob with mine once. I was not getting a good ground on the wire. I would try that first.
Old Feb 23, 2003 | 01:03 AM
steve83's Avatar
steve83
It has to be a bad ground - as soon as you press the button, the display should start to flash, showing that you're changing the conversion constant. Either that, or you're pressing the wrong button.
Old Feb 23, 2003 | 09:29 AM
2Wise4aGM's Avatar
2Wise4aGM
I figured it out guys. It was just like you said-BAD GROUND. Apparently the jumper wire that I was using has a bad spot in it.
I went and grabbed a different jumper wire and it worked perfectly.
Thanks again for your help guys!
Mark
