I have a 1989 7.3L E350 van and having problems bleeding the lines.
I replaced the Injector pump this spring and got my rig running. Ran it to town once to check it all out and then parked it for the summer.
Last week I tried to start it no luck. I have checked it out and cannot figure what is happening.
I replaced the fuel filter (filling it with diesel)
I have 12 v to the cold start and shut off
When I crack the nut loose on the line at the intake to the injector pump i am getting fuel out when I crank it over.
There is a trickle of diesel coming out of the injector pump return line (I have a clear fuel line here so I can see it trickling through)
Any thoughts?
I really would hope there is something more to do than pull this new rebuild injector pump off and send it back.
When the injector lines are all cracked and your cranking it over, the fuel lever needs to be in the wide open postion to effectively and quickly bleed the lines. just a thought, also make sure the power is getting through to the fuel shut off soliniod, maybe a loose or corroded connection not allowing enough voltage open the soliniod?
there should be a check ball or rubber check valve on the fuel filter header and the line should go to the return , it will pump air and wont start . on mine i just blocked it off .
i dont think that part is available any more !
The return system is a critical component of these motors, you cannot just block them off ... Best thing you can do is return the Fuel Return system to a properly working condition and layout.
At the Schrader valve on the filter head you have 1/3 pint in 10 seconds of cranking at 4-7psi ???
If internals of the IP are frozen the best thing you can do is Fill the IP full of Stanadyne Lubricity Formula and let it soak for a day or two.
You can pull it apart, however do not do so with out a manual, improper assembly could cause a run away motor ... Kaboom!
hey festus on my truck that check valve or what ever the proper name is on the filter header was shot and ford told me that it is not available at least were i am at . that is on the 7.3 idi , my old 6.9 was completely different . and if one chooses to run different style of filters then all that garbage would be eliminated . on all of the other diesels that i have
from tractors to drill riggs , compressors , power supplies , none has that type of filter head on them . and they all have the rotary pump
We are talking about the International (Navistar) IDI motor in Ford trucks, not a farm tractor, drill rig compressor or whatever else!
If one chooses to eliminate the return system then one deserves the headache it creates ...
haplo, To fill the IP with a lubricator, pull the filter, pour it out in a jug or something, fill it with the lubricator, reinstall it ... Crank the motor for about 10 seconds, let it set.
festus chill out since i blocked it off 2 years ago there has been no problems . all the return lines are run to the tank just as they came from ford , just that little valve thing is blocked of
