Just replaced the upper pin in driver door, took the play out.
Next is how to get door closer to seal at top?/?? I can see light at the top below the curve down. The gaskets/seals don't look too bad; although it is a 96.
Is it out of alignment at the fender too? If so, you may have to shim the hinges...if not, then roll the window down and close the lower portion of the door on a 2X4 and push the top of the door in.
