fuel pump removal
Old Oct 3, 2010 | 09:39 AM
sswebber's Avatar
sswebber
fuel pump removal
OK iv narrowed it down to the fuel pump any tips or advice on changing it out would be greatly appreciated...thx 04 f250 6.0 litre diesel
Old Oct 3, 2010 | 11:23 AM
sswebber's Avatar
sswebber
Was actually very simple to replace. Three bolts and right out it came.
Old Oct 3, 2010 | 11:31 AM
cheezit's Avatar
cheezit
yup 3 bolts and 4 lines. not a big issue. glad you got it handled.
Old Oct 3, 2010 | 04:35 PM
dchamberlain's Avatar
dchamberlain
Did that solve your fueling problem?
Old Oct 4, 2010 | 04:38 AM
sswebber's Avatar
sswebber
Ill get the new pump this afternoon and ill post my results, i sure hope this fixes it.
Old Oct 4, 2010 | 12:09 PM
smokersteve's Avatar
smokersteve
yea let us know how it does
Old Oct 4, 2010 | 08:14 PM
sswebber's Avatar
sswebber
Well i replaced the pump with no luck removed fuel lines again blew through lines and it still doesnt prime....any more ideas guys...thinking i will check cap and o-ring again but iv looked at both several times.
Old Oct 4, 2010 | 08:17 PM
cheezit's Avatar
cheezit
did you check and varify the pump is comming on? check power and ground to it yet?
Old Oct 4, 2010 | 08:40 PM
sswebber's Avatar
sswebber
Yes cheezit the pump comes on and runs for 15 secs or so just willnot prime
Old Oct 4, 2010 | 08:43 PM
cheezit's Avatar
cheezit
ok take the upper filter off and cycle the key 2-3 times. waiting aprox 30 seconds between cycles. note this may make a mess with fuel on the engine and ground if it floods the bowl.
this may also sound stuipid but.... are yoy sure the sending unit in the tank is accuratly showing you have fuel in it? try adding a few gallons from a can.... been down this road before too.
Old Oct 4, 2010 | 08:50 PM
sswebber's Avatar
sswebber
i can blow bubbles back through the sending line and if its empty the mileage is also off and i actually tried cycling with the upper filter offprob five times and no fuel showed up,i then removed the fuel line leaving hfcm and still no fuel when i cycled.
Old Oct 4, 2010 | 08:52 PM
cheezit's Avatar
cheezit
from waht its sounding like you either have an air leak or a blockage.
Old Oct 4, 2010 | 08:57 PM
sswebber's Avatar
sswebber
I can blow through both lines on tank side and the line with the arrow pointing towards engine,all of this started when i changed my filters, maybe i created a leak some how on the hfcm ....not sure how to test for leaks though. I can not blow air through the lin returning from engine but was unsure as to whether i should hav been able to
Old Nov 3, 2010 | 12:22 PM
stupidjet's Avatar
stupidjet
did you ever figure this problem out? why are there many threads about problems after filter removal but never any answers? lol hope you got it fixed.
Bounds-Electric
6.4L Power Stroke Diesel
Oct 3, 2011 02:33 PM
gt40racing
Mar 16, 2011 06:14 AM
pf350
Oct 18, 2007 11:00 AM
buckford
15
Sep 19, 2004 08:33 PM
