HISS
Old Oct 3, 2010 | 08:07 AM
armstrongfordtrucks's Avatar
armstrongfordtrucks
Question HISS
Took the new girl or a 1000 mi trip yesterday. Noticed maybe 3 problems.
2000 F-350 PSD AUTO 4X4 CC 125000 miles.
First being looks like oil on tip of exhaust, about the last 4" of the pipe.
Second being sounds like it has a miss, if it was a gas engine I would thing it had a bad plug.
Third is when it shifts it has a hiss, especially when it shifts into od. Think it is turbo related, sounds like maybe a leak.
Thanks in advance.
armstrong
Old Oct 3, 2010 | 08:50 AM
F350-6's Avatar
F350-6
Are you low on oil? Oil in the tailpipe sounds like a turbo issue. Got any play in the shaft?
Old Oct 3, 2010 | 09:56 AM
00Dave's Avatar
00Dave
I will agree with Chris on the oil in the tailpipe issue. From what I have read, not experienced. The miss MIGHT be a loose uvc harness. This is located under the valve cover. Just a guess. The hiss, my first ? is, do you have an aftermarket air intake? It seems to me that mine was louder on the hiis after changing tha air intake to the 6637.
Old Oct 3, 2010 | 10:48 AM
Waynenap's Avatar
Waynenap
I have a S-B CAI and a 4" TB exhaust and I get the Hiss when it shifts, including the more pronounced going into OD. I assumed that was normal, hope it is.
Old Oct 3, 2010 | 10:50 AM
armstrongfordtrucks
I will check the oil, have not yet today although full when I left. The air filter is from Riffraff 6637 and this is the first trip crusin with it. I will reinstall the factory one to be sure. The exhaust is 5" straight through, and was that way when I purchased it. That may be the miss sound I hear because I'm sure the sound from it is different then the 97 I just sold with 3" straight through. The 97 just sounded great crusin, nice and even, but 2000 sounds like it's just not right.
Old Oct 3, 2010 | 02:00 PM
Waynenap's Avatar
Waynenap
Here's a bump for you.
Old Oct 3, 2010 | 05:55 PM
F350-6's Avatar
F350-6
If this was your first trip with the 6637, then as Wayne said, that could be your hiss. Those filters make some different sounds, but a hiss is normal.
Oil out the tailpipe is not. Check that.
Old Oct 3, 2010 | 07:46 PM
armstrongfordtrucks
Just checked the oil, down maybe 1/2 qt from the trip. Will have to figure out how to check shaft play. Is there a write up with pic's on this anywhere ?
thanks
armstrong
Old Oct 3, 2010 | 08:09 PM
F350-6's Avatar
F350-6
thanks
armstrong
A 1/2 quart doesn't sound too bad, so I'd relax a little if I were you. Checking the shaft play is pretty easy. Remove the plastic tube that connects to the turbo. Then (with the engine off of course) reach in and grab the shaft at the center of the turbo wheel with your fingers. A little up and down or side to side play is fine as long as it does not look like the wheel has been scraping on the sides. There should be no in and out play on the shaft as you wiggle it with your fingers. If there is any in and out play in the shaft you need to rebuild your turbo before it goes boom or starts laying a smoke screen behind you.
Lindseth
2004 - 2008 F150
Jun 20, 2014 06:00 AM
Pridnjoy
Sep 7, 2013 08:50 PM
JAMSRF250
May 6, 2008 07:04 PM
serussell
Mar 4, 2007 09:19 AM
Munkey
Modular V10 (6.8l)
16
May 13, 2002 11:32 AM
