Edge insight CTS problems. HELP!
Old Oct 2, 2010 | 11:31 PM
jims406rs's Avatar
jims406rs
Got my CTS installed and there is no PID for Trans fluid temp, boost, or eot. Im sure there are others too. Why do some people have these and mine doesnt? 04 F250 6.0
Old Oct 3, 2010 | 07:17 AM
jims406rs's Avatar
jims406rs
anyone?? ...
Old Oct 3, 2010 | 08:50 AM
imaposer's Avatar
imaposer
You will need to call them and have them send you new programming for it to display all features on an '04 truck. It wouldn't hurt to hook it up to your computer and see if there is an update available for it that already contains the needed changes. Last I heard, it was still in testing, but they will send it out if asked.
Old Oct 3, 2010 | 09:20 AM
Zmann's Avatar
Zmann
it should all be there .. you canplug it in to your computer and check for updates but they are so new I doubt yours will need it ,, also make sure it asked you what vehicle and it looked for your vin.. if not unplug from your truck and it and do it again
Old Oct 3, 2010 | 09:59 AM
jims406rs's Avatar
jims406rs
I did the update before I hooked it up. It ask for the make so obviously o enter ford but it doesn't read the VIN. I have repeated several times with same results. I am at a loss.
Old Oct 3, 2010 | 10:01 AM
Zmann's Avatar
Zmann
you are cycling the key to on correct?
Old Oct 3, 2010 | 11:10 AM
Zmann's Avatar
Zmann
ps you can flip the OBD port on the truck ,, it helps keep the wire out of the way
Old Oct 3, 2010 | 11:37 AM
imaposer's Avatar
imaposer
The update I am talking about that you have to call them up and get will let you manually enter the vin number in, then you will get the other pids. BTDT.
This is only an issue on 2003 & 2004 6.0.
Old Oct 3, 2010 | 11:42 AM
Zmann's Avatar
Zmann
AH thats why I didn't run into the prob
Old Oct 3, 2010 | 11:48 AM
imaposer's Avatar
imaposer
I bought one when they first came out, and was pissed that it didn't give me all the info I expected. I worked with a guy there on it proving that there was an issue, and when they gave me an estimated time to fix of six weeks, I sent mine back.
Two days later he emailed me and said they had a fix and he wanted me to beta test it. I had a friend who was more patient than me who kept his, so he did it on his truck. It took a couple of tries, but he got his working. I ordered another one, put the beta test update in mine, and it has worked perfectly ever since. Finally let me diagnose and fix my overheating problems as I could really see what temps things were(and in my case were not) happening at.
If you call them, and they say they have no idea what you are talking about, ask for the tech department and talk to Rob(if I remember correctly, it's been a few months).
Old Oct 3, 2010 | 03:25 PM
Zmann's Avatar
Zmann
kinda lame ,, why the just don't post the download?
Old Oct 3, 2010 | 07:35 PM
AndeyHall's Avatar
AndeyHall
Because from what the guy told me that sent me the update, it's still in testing because they're still having several people that get the update and it makes their unit go crazy, so they have to "un-update" it. But according to the guy I talked to, it's not necessarily just a problem with '03s and '04s, it's just a problem with tuned '03s and '04s because of the VIN being erased off of the PCM.
Old Oct 3, 2010 | 07:52 PM
imaposer's Avatar
imaposer
Not just tuned, any '03-'04 that has had any work done to it where new data has been written to the PCM. Back then, even ford was guilty of taking a shortcut and not saving and rewriting the vin data back when doing updates.
Old Oct 3, 2010 | 08:04 PM
AndeyHall's Avatar
AndeyHall
Oh ok. Learned something new today then...never knew that.
Old Oct 3, 2010 | 08:44 PM
Zmann's Avatar
Zmann
Edge should not have rushed to the plate with this ,,
