I haven't tried it, but I don't see any problem if you were replacing a 6/cy or 302 as the housing would bolt up. The 289 would have a 28 oz. balance where the other two may have a 50 oz. I have a 66 289 and a 84 302 in my shop, the 289 will rev up faster from idle. I tried them both in the same car and as far as performance, I could not find much difference. In a truck though it may show up different as the truck may be ask to work a little harder. My $.02 W.
thats better, now my nit picky, crotchity personality is satisfied, lol . To the original question 289 is a fiesty little sucker and will drop in anywhere a 302 will go, butt there are many more 302's to be found as buildable 289's are getting scarce and more cubes never hurts imo !
289 was first, 302 came along later. 289 couldnt be a destroked 302 because in there day the 302 didnt exist yet
Right. The 289 was introduced in '63...the 302 was first put on the street in '68, which was also the last year for the 289.
Dom, I was looking at a '75 truck that had a 289 swapped in for a stock 302, and the guy selling it was clear in saying he didn't like it because it couldn't pull as well as the 302. I didn't care and he knew I didn't care, because I told him I just wanted it for the body. Otherwise, I have had no occasion to even look at a 302 or 289 truck.
Personally, I don't think 302s belong in older trucks. They weren't made to be truck motors...they just filled the need for a small V8 between the six cylinder and the FE.
I do, however, think that a warmed up 351W would serve you well. Same bellhousing pattern, more power, comparable size...Ford used it in a lot of F350s in the 80s and 90s, where it did an admirable job as a pulling motor.
I wasnt exactly trying to establish the chronological order of the small block Ford engines of the late '60s-'70s lol but thanks, I stand corrected. I agree with Bowtie on not liking like these motors in pickups, I personally would prefer a 300 six, I have driven F 150s with both (302 and 300) in stock form and the 300 was easier on gas and pulled just as well if not better.
Reason: grammar
agreed on the 302vs300 , it was a sad day for all when Ford stopped using those torqey little inlines. And Bowties right about 351 being better truck motors, again more cubes never hurt anyone lol
Hey Dom, I have a 289 engine, top loader 4 speed and a posi rear end from a 1968 Cougar in my 1974 Ford Short box Dentside truck the engine is done up too bored out 40-60 thou over headers mild cam Edelbrock 600 cfm carb goes good enough for me! I don't use it to haul things.I bought it off a guy that way!
