clattering
Old Oct 2, 2010 | 08:49 PM
remix01's Avatar
remix01
clattering
does anyone know why I get clattering running 87 octane ,but when I run 91octane its just fine no clattering or pinging? Its a V10 w 154k on the clock.thanks
Old Oct 3, 2010 | 10:11 AM
jh818's Avatar
jh818
Sounds like something wrong with your computer. Back in the 80's, cars used to have knocking (dieseling) using regular unleaded. Lead in gasoline was an anti-knocking agent.
Cars today use computers to adjust timing, etc. to prevent knocking.
Have you changed your plugs and boots?
Old Oct 3, 2010 | 11:01 AM
remix01's Avatar
remix01
I meant 93 octane ,I have not tried 91 yet. I bought the X with 141k and dont know if the plugs and boots have ever been replaced, should I start there?
Old Oct 3, 2010 | 12:42 PM
TYZ78F150's Avatar
TYZ78F150
At 141k, I'd start with a full tune up. Plugs, boots, pcv valve, all fluids, fuel treatment. Sounds a little redundant, but it's hard to tell whats been done, and what hasn't by the PO.
Old Oct 3, 2010 | 01:15 PM
cbradford's Avatar
cbradford
What he ^^^^ said.
Old Oct 3, 2010 | 01:20 PM
Monsta's Avatar
Monsta
Sit. Stay.
I'll third that! You definitely need to pull a plug (or 10) to check them. My guess is that they are well worn.
If not, there is a knock sensor below the intake manifold that could be bad.
Old Oct 3, 2010 | 08:57 PM
moto4's Avatar
moto4
And just in case you didn't know, after you remove the COP and boot, blowout the plug chamber with compressed air before removing the plug.
Old Oct 4, 2010 | 02:08 PM
TYZ78F150's Avatar
TYZ78F150
Yes. Make sure and blow out those holes. You'll be suprised how much crap gets built up in them, and you don't that stuff falling down in the cylinders.
Old Oct 4, 2010 | 02:35 PM
nagetech's Avatar
nagetech
Smile
Howdy!
Please excuse me if this is a dumb question (I'm still learning)... when you saying you hear pinging... Are you talking about pinging/nose coming from underneath the truck?
I ask because I've always noticed, since I got my X, that after a good long run, I hear pinging sound coming from underneath the truck from what I assume to be the Exhaust pipes. Is that normal?
Thanks in advance!
PS. Don't mean to thread hijack!
Old Oct 4, 2010 | 02:52 PM
Monsta's Avatar
Monsta
Sit. Stay.
Sometimes you can get a rattling sound at a particular RPM that emanates from a loose heat shield on the exhaust pipe. Is your sound after you turn it off?
The rattling the OP (Original Poster) describe sounds like spark knock (pinging) since it goes away with higher octane fuel.
Old Oct 4, 2010 | 03:14 PM
nagetech's Avatar
nagetech
I'd descbibe the sound more like.... little rocks hitting my exhuast piping...if that makes sense? The sound is definitely underneath the truck itself! I haven't tried using a higher ocatne gas. Makes me curious to see if it makes the sound go away!
Old Oct 4, 2010 | 03:32 PM
remix01's Avatar
remix01
The sound is definitely coming from the engine, it happens mainly when I accellerate .
Old Oct 4, 2010 | 05:21 PM
Monsta's Avatar
Monsta
Sit. Stay.
Not sure what year your truck is but early V10 Excursions are famous for exhaust flutter. What year is your truck?
Roger that.
Old Oct 4, 2010 | 07:50 PM
nagetech's Avatar
nagetech
Howdy!
I have a 2003 X V10.......
I dont hear the sound when I accelerate, just when I turn it off and am walking away from it! Got me wondering of that is normal or not
Old Oct 4, 2010 | 09:21 PM
moto4's Avatar
moto4
Howdy!
Yeah, I think you are fine. That is just the exhaust pipes/shields cooling off at different rates.
