Awhile back my fuel selector valve went bad and the 6port valves are not cheap so i was wondering if the design below would work. Each tank would have a low pressure electric pump that would push the fuel to the motor. the fuel would push the ball to the opposite side of the valve blocking off the other tank. The pumps and the gauges would be controlled by a double pole single throw 2 position switch. still haven't figured out what to do with the return lines though.
I know that some of you don't like electric pumps on these IDIs but this is more of a proof of concept question then anything else.
You'll spend more money and time then it's worth ... Do you think Ford would have done it the like it is if there was an easier less expensive way to do it ...
There has to be a positive connection to both the supply and return switching valve!
So if one changes the other does as well.
No, It must return to the tank it's feeding from else It'll over flow the tank ... The manual lift pump pumps about 35GPH, the motor doesn't use nearly that much, it goes through the return system!
Thus it would empty one tank into the other rather quickly.
Tried a u-pick-it wrecking yard? I got one there with the plastic fuel line for $30. Check the wiring connector. They are not all the same. To be safe, take the connector with enough wire to splice when you get back home
o Instrumentation Ball Valves
+ 360 Series 2-Way Ball Valves
+ 390 2-Way 90° Ball Valves
+ 3200 Series 3-Way Ball Valves
+ 4100 Series 4-Way Ball Valves
+ 5200 Series 5-Way Ball Valves
o Mulit-Port Dual
Control Valves
+ 35000 Series Stack Valves
+ 9000 Series Stack Valves
o Ball Valves
+ 120 Series 3-Way Diverter
+ 160 Series 2-Way In Line
+ 190 Series 2-Way 90°
+ 350 Series Mini Ball Valve
o Needle Valves
+ V1 Series Semi Metering
+ V3 Series Full Metering Function
+ 90 & 900 Series Rising Stem Valves
o Selector Valves
+ 100 Series Selector Valves
+ 200 Series Selector Valves
+ 6-Port Selector Valves
o Manifold Valves
+ Gage Manifold
+ 3 Valve Manifold
+ R V Water Management
o Check Valves
+ 740/750 Series
o Specialty Valves
+ K2 Series Toggle Valves
+ PB Push Button Valves
+ 234 Series Strainers
o Shut Off Valves
+ M670 Series Marine Fuel
+ 130 Series Shut Off
+ 30 Series Drain Valves
+ 247 Series Drain Valves
* RV Fill Stations
* Kantleak Manifolds
* Corporate Profile
* Standard Catalog
* Complete Custom Valves
* Multi Port Stack Valves
* Configurable End Connections
* RV 4 Way Valve
* Opportunities
* Brass Surcharge
* Contact Us
SELECTOR VALVES 3, 4 & 6 PORT
100 AND 200 SERIES PLUS SIX PORT FUEL VALVES
SELECTOR OR SWITCHING VALVES
100 Series 3 Port
200 Series 4 Port
SK1036 Six Port
FEATURES / BENEFITS APPLICATIONS SERVICE CONDITIONS
Forged Brass Body Fuel Switching Maximum Pressure : 30 PSIG on 100/200
Plug Style Valve Tank Selection Maximum Pressure : 15 PSIG on SK1036
Mounting Brackets Mixing Operations Temperature: -40F to +180 F
Made in USA
Part Number Material Port Size Click Stop # Ports Stem Length
210C-J Brass 1/8" F NPTF Yes 3 1 3/8"
110C-L Brass 1/4" F NPTF No 3 1 3/8"
210C-L Brass 1/4" F NPTF Yes 3 1 3/8"
210C-LS Brass 1/4" F NPTF Yes 3 3/4"
210C-LM Brass 1/4" F NPTF Yes 3 2 3/8"
110C-N Brass 3/8" F NPTF No 3 1 3/8"
210C-N Brass 3/8" F NPTF Yes 3 1 3/8"
100C-L Brass 1/4" F NPTF No 4 1 3/8"
200C-L Brass 1/4" F NPTF Yes 4 1 3/8"
100C-N Brass 3/8" F NPTF No 4 1 3/8"
200C-N Brass 3/8" F NPTF Yes 4 1 3/8"
205C-L Brass 1/4" F NPTF Yes 4 2 3/8"
205C-N Brass 3/8" F NPTF Yes 4 2 3/8"
215C-L Brass 1/4" F NPTF Yes 4 3 3/4"
115C-N Brass 3/8" F NPTF No 4 3 3/4"
215C-N Brass 3/8" F NPTF Yes 4 3 3/4"
SK 1031 Brass 1/2" x 3/8" F NPTF No 6 5/16"
SK 1036 Brass 1/2" x 3/8" F NPTF No 6 13/16"
1629 West Bobo Newsom Hwy., Hartsville, SC USA 295501.843.332.4111 • 1.800.476.9876 • Fax: 1.843.332.3752
Groco 6 Port Fuel Valve
Six port fuel valves are used where 2 tanks supply a single engine and a return to each supply tank is required.
Price: $ 149.95 / Each
International Flat Rate Eligible.
Discount Marine Supplies
PO Box 180
Hershey, PA 17033
United States
Ph: 1
e-mail: orders@discountmarinesupplies.com
Qty Item Price
Your cart is empty
Click to view this Product
Racor Universal Gasoline Fuel Filter Replacement
This gasoline filter/water separator replaced standard filte...
Price: $ 9.95 / Each
Add to cart Enlarge
Racor Closed Crankcase Ventilation System
Closed crankcase systems are designed for your turbocharged ...
Add to cart Enlarge
MOELLER 24 GALLON BELOW DECK TANK (STARBRD SIDE)
Polyethylene tank which is corrision and pit resistant. Each...
I thought someone here had found or used a generic valve from autozone or someplace, just took a bit of thinking to get the hoses and wiring hooked up?
