Sponsored by: Innova
Fr: door panels on 99 SD
Old Oct 1, 2010 | 06:31 PM
tankhead's Avatar
tankhead
Can you help me on how to remove the panels to replace the speakers? I see a bolt when I remove the red reflector light and the mirror/window control panel. Do I remove them both. Will I need to disconnect the harnesses attached to the mirror/window control panel? I was looking at some Infinity Infinity Reference 6832cf 2-way car speakers for 5"x7" and 6"x8" openings at Crutchfield.com. Thanks!
Old Oct 2, 2010 | 12:10 PM
rustydailey's Avatar
rustydailey
You remove the screw behind the reflector, then pull the switch panel up and unhook the wires and there is another screw there. Then you remove the mirror trim and then pull the whole thing straight up.
Airslot
Feb 14, 2011 07:14 PM
speckfisher
Electrical Systems/Wiring
Dec 26, 2009 05:43 PM
97ExpGuy
Nov 10, 2009 12:44 PM
FTL40
Aug 31, 2008 08:54 PM
