Engine surges when clutch depressed
Old Feb 22, 2003 | 10:27 AM
JamesDuffer's Avatar
JamesDuffer
Question Engine surges when clutch depressed
1989 Ford F150 Ford Lariat, 302 V8, manual transmission. The engine surges (races) as I change gears..with the pushing in of the clutch pedal...do not to have to press accelerator... After several miles this sympton seems to disappear. I haven't taken it to the shop for this problem and am thinking of trying to find out what it is and fix it. A friend of mine suggested "throttle position sensor"....Does anyone else have any ideas? Or had the same problem before?
thanks for reading this.
Old Feb 22, 2003 | 05:18 PM
coolgreen's Avatar
coolgreen
My 1989 f150 4x4 302 5-speed is doing the same thing. No one seems to be able to figure it out. Mine used to do it only when the motor was cold, but recently started doing it all the time.
I replaced the idle air control valve, which did nothing.
I hope there's an answer to this, becuase the revving between gears is driving me crazy, especially when I'm plowing snow.
Old Feb 22, 2003 | 05:28 PM
omni's Avatar
omni
I under stand that on standards when you press the clutch in to shift, the rpm is suppose to hang there for a few seconds so when you let the clutch out you get a smoother shift, but what ever controls that is acting up, mine does that as well, I have the 300 six 5 spd, whats with all this fancy computer ****, it would be ok if it worked, take me back when controling the rpm was done by your foot
Old Feb 22, 2003 | 05:48 PM
lexluthr69's Avatar
lexluthr69
Check to make sure your idle set screw isn't protruding past where it should be. I know that you can slightly adjust the idle with the screw but if ya do so, you'll be fighting the computer to control the idle. I ran into very similar symptons last summer and after replacing the IAC Valve, I reset the idle screw back to norm and it worked great.
Just an idea.....
Old Feb 23, 2003 | 12:08 AM
gamehunter's Avatar
gamehunter
I know what you mean, I have the exact same thing on mine. But for some reason it happens alot more often during the winter time. Somehow, excess air is getting into the engine that is unwanted. My truck sometimes can even "drive" itself down the road for 5-10 seconds. It is quite bothering, but I have not found the cure for mine yet. However, good chance it is a variety of things.
Old Feb 23, 2003 | 01:10 AM
steve83's Avatar
steve83
To reset the throttle stop screw, start the engine and let it warm up. Make SURE you don't have any vacuum leaks or other intake problems. Then unplug the IAC - the engine should struggle, then die. If it keeps running, back the screw out slowly until the engine ALMOST keeps running, but dies. If it dies immediately when the IAC is unplugged, screw it in slightly and try again.
You should ONLY do this if you think the screw is NOT at the factory setting.
When you're finished, plug the IAC back in, trigger the codes, and clear them.
Old Feb 25, 2003 | 04:44 PM
glazer1972's Avatar
glazer1972
My 93 5.8L kept doing this. Everbody said electrical, sensor, computer, IAC valve, TPS, yada yada yada. I changed a bunch of crap and checked a bunch of crap to no avail. I took off the Throttle Body and manually operated the butterflys while holding it close to my ear and lo and behold the was some slack on the shaft that was allowing air past the butterflys. I ordered a new throttle body from Ford and it included the TPS and IAC. (some of the parts I had already changed) Installed the new throttle body and it hasn't done it since.
Hope this helps!
Old Feb 25, 2003 | 10:02 PM
8996EBBroncos's Avatar
8996EBBroncos
I had the same problem. But before going out and buying a new TB. Take the TB off and clean it real well with TB cleaner. I did this and I don't have to worry about slamming into the rear of someone at a stop light now.
Old Feb 26, 2003 | 11:42 AM
Yogi2899's Avatar
Yogi2899
Excuse my ignorance, but what is a good throttle body cleaner? Is there any brand name you would recommend? I have the same problem and the guy I bought the truck from was told the Sensor was bad.
Old Feb 27, 2003 | 08:32 PM
steve83's Avatar
steve83
Gunk is probably the best brand name in automotive chemicals.
To ID a vacuum leak at the throttle shaft, just spray some thick oil (like aerosol white lithium grease) on both ends of the shaft while the engine is running and observe the idle. If it drops temporarily, you just plugged a leak.
Old May 8, 2022 | 08:50 AM
Stealth126's Avatar
Stealth126
4wd Low
My 89 F250 302 5 speed manual started doing this recently too. There didn’t seem to be any slack in the throttle body but one of my Ford technician friends told me to spray just a little bit of carb cleaner into the throttle body while the truck was running and slightly rev it a bit. I cleaned for 6 or 7 minutes and now not only is the surge gone but the truck idles better and runs just a touch cooler on the temp gauge. He told me to make sure I sprayed the window to the sensor as well. I suppose the intake valves must have got some cleaning as well.
Tim Hodgson
1978 - 1996 Big Bronco
Jan 6, 2015 12:43 AM
christopher
Dec 26, 2014 05:16 PM
Tim Hodgson
Dec 21, 2014 10:26 PM
almonyspm1
Sep 21, 2013 08:27 PM
Dr. Dirt
1997 - 2003 F150
Jan 5, 2013 08:49 AM
