Air Bags
#46
I have a rather stupid question... how do you drain/fill these airbags without an air control system? I have an air compressor (and a second air tank) in the garage. If it's just a matter of routing a line to an easily accessible place... airbags might be in the near future for me. I could feasibly carry the air tank with me to make any adjustments on the road. thoughts?
#47
Ford F250 / F350 Firestone Air Bags
#48
I tow 6 different trailers and have many different sets of gear I load so I use the in-cab gauge connected to an air compressor and I can change the pressure while I drive as much as my heart desires. Very nice. If you stick with the standard route, you'll learn your psi preference and it's easy to deal with. No need to carry a tank as long as you can find air at a fuel stop.
#49
#50
#51
#52
I installed the Timbrems today and with the camper in the truck bed (Lance slide in truck camper) the overload springs are contactng the rubber frame mounted points. With my 08 the Airbags didn't allow the helper springs to contact. I had the bags set so the helpers were 1 in away from contact. This is how my camper dealer told me to do it.
So I prefer air bags now as they will hold up more weight.
Also AIR LIFT now has a kit for our trucks. It's part number #57396 no drill.
Saxon
Car/truck Buying Advice
06-14-2004 11:57 AM
