97 Explorer code 0174 & 0171
Old Oct 1, 2010 | 12:03 AM
5fingerblu's Avatar
5fingerblu
My 97 Explorer 5.0 has been lighting up the check engine light often. Code 0174 pops up, system too lean (bank 2). Any idea what may be causing this. Thx in advance I have adjusted the error code straight from the book. Added new code today 0171 system to lean (bank 1)
Old Oct 5, 2010 | 10:47 PM
5fingerblu's Avatar
5fingerblu
To answer my own question. Cleaning the MAF sensor as solved my problem with the error codes.
Old Oct 6, 2010 | 07:07 AM
shorod's Avatar
shorod
Thanks for the follow-up. Interesting that originally the MAF would set a code for a single cylinder bank as the air through the MAF feeds both cylinder banks. Hopefully this proves to be a long-term fix for you though....
Out of curiosity, are you using a OEM-style paper air filter or do you have an aftermarket oiled filter?
-Rod
Old Oct 6, 2010 | 04:44 PM
5fingerblu's Avatar
5fingerblu
Rod The error codes alternated between the two never knowing which one would appear. I am using K & N shorty cold air kit in use for about 5 years now. Dennis
Old Oct 6, 2010 | 08:02 PM
shorod's Avatar
shorod
Okay, makes sense with the K&M that the MAF may be dirty. The oil from the filters has a tendency to coat the elements of the MAF. You'll probably notice a decent improvement in fuel economy now too.
-Rod
Old Oct 6, 2010 | 10:48 PM
Fifty150's Avatar
Fifty150
Those common emissions related codes can be such a pain.
