Horn button wiring
Old Sep 30, 2010 | 10:15 PM
bkaul's Avatar
bkaul
Horn button wiring
I'm trying to get my horn working via the button, wasn't hooked up when I bought the truck. The horn works fine when I jumper between the center post and the 1/4" spade in the steering wheel. I just need to figure out how to plug in the horn bar ... the female terminal obviously goes on the spade, but there's another wire hanging off the back with a 180-degree-bent male spade terminal on it, and there's no obvious place to connect it. Where should that go? Am I missing a piece that should connect it to the center column bolt/nut somehow?
Old Sep 30, 2010 | 10:41 PM
Witty73's Avatar
Witty73
Its the ground, it simply sticks in one of the holes in the center bar of the steering wheel.
Old Oct 1, 2010 | 11:08 PM
bkaul's Avatar
bkaul
Ah, thanks! I'd figured out from a wiring perspective that it should attach to the center hub as a ground; hadn't thought to stick it in one of the puller bolt holes though. That works perfectly.
Old Oct 15, 2010 | 11:54 PM
brseidel's Avatar
brseidel
Wow! I just has the same stupid question. Put "horn wire" in the forum search and voilà. The internet rocks almost as much as you guys.
mikeceli
Jul 19, 2016 03:51 AM
jvmcc
May 31, 2016 12:00 PM
fromme87
Dec 1, 2015 08:59 AM
stang9090
Sep 24, 2015 04:00 PM
