recalibration???
Old Sep 30, 2010 | 09:49 PM
grayghost316's Avatar
grayghost316
recalibration???
i have a 92 f-150, 4x4,supercab when i bought the truck it had 31 inch tires. over time i've gradually gotten bigger until i got to 33's. the question i have is. can running these bigger tires cause performance issues? i know it will throw the speedometer calibration off. but can it cause my truck to hesitate or pull back when going up hills or accelerating. does this model truck have a computer that would need to be reprogrammed for larger tires? it has the e4od tranny. i've noticed that it doesnt pull back as bad when i turn overdrive off. i have the 351w engine. my mpg is around 11mpg. is that normal? seems like it should be higer with efi. could i possibly have a tranny problem? any info or help with this is appreciated.
Old Sep 30, 2010 | 09:53 PM
timbersteel's Avatar
timbersteel
Running that size tire is gonna have an impact on MPG. Also what gearing do you have? That makes a big difference as well. Some other posters can chime in and they will give you a more detailed view of tires vs. mpg vs. performance.
Old Oct 1, 2010 | 09:22 AM
rla2005's Avatar
rla2005
The computer is making decisions based on a specific tire size. Now that you have changed one of the parameters the PCM needs a corrected speed input. The PSOM needs to be updated with a different calibration constant to compensate for the larger tires.
Here is a writeup from another forum: What's a PSOM & how do I "P" it???
Thanks to Steve83
Old Oct 1, 2010 | 09:36 AM
F-350 Mud Digger's Avatar
F-350 Mud Digger
HOW TO RECALIBRATE THE SPEEDOMETER ON 92-96 FORD F-SERIES AND BRONCO .: Articles
afbrian13
Dec 13, 2012 08:52 PM
Ak Ford Man
20
Feb 4, 2011 12:42 PM
bowdog
1997 - 2003 F150
Aug 27, 2008 07:45 AM
51dueller
General Automotive Discussion
Apr 12, 2006 10:26 AM
beefFX4
2004 - 2008 F150
15
Feb 14, 2006 11:12 AM
