Sponsored by: Real Truck
6.4L Coolant Problems
Old Sep 29, 2010 | 07:44 PM
LoneStarLegend's Avatar
LoneStarLegend
Angry 6.4L Coolant Problems
Help me out, guys. My '08 F250 is losing coolant, and I don't know where. It's not getting out(according to the gauges), not putting out white smoke(except in regen. mode), and is not leaking that I can see. I'm losing a gallon every week or so, and I started to smell it the other day. I'm told it maybe a sensor causing the coolant to reach higher than normal temps.
Old Sep 29, 2010 | 08:16 PM
gearloose1's Avatar
gearloose1
Warranty.
Could be anything from EGR cooler to Head Gaskets.
Old Sep 30, 2010 | 06:50 AM
ruschejj's Avatar
ruschejj
Look very closely at the bottom corners of the radiator for evidence of coolant drips. Pretty easy to see.
Look at the degas bottle to see if has puked any out the top.
Otherwise, it must be getting passed into the combustion chamber or the EGR cooler. A slow leak/small leak will stop when the engine gets hot but leak into the EGR as it sits overnight. A diesel tech can do pressure tests to see where the leak is. (unless you have the stuff)
Old Oct 1, 2010 | 06:01 PM
LoneStarLegend
Thanks, guys...I knew all of these possiblities, but thought someone might have something simple! I'm taking her in! Rental, here we come.
Old Oct 1, 2010 | 08:45 PM
senix's Avatar
senix
might want to address the white smoke issue while you are there. I may help them to see what the deal is.
How is your oil level?
Old Oct 5, 2010 | 04:02 PM
LoneStarLegend
Well, there is a TSB on my truck for a bad thermostat causing the radiator to go bad. Turns out mine was replaced just before I bought it(used) at 31000, and now the second radiator goes out. Neither time did they replace the thermostats, and they didn't perform the test that Ford lists on the TSB to determine if they were bad...They just tore into it and looked at them. On top of that, they charged $1580 to replace it. The radiator is one of the last things I would expect to go out on my pickup. I've never had to replace....EVER. Now the fight with Ford begins, I guess. Does anyone have any ideas as to who to contact? The dealer said they were going to try, but I don't expect much.
Old Oct 5, 2010 | 04:03 PM
LoneStarLegend
Did I forget to mention that my truck only has 63000 miles on it? This will be radiator #3!
Old Oct 5, 2010 | 04:07 PM
LoneStarLegend
Oil level is fine, by the way, Scott. I forgot to mention the white smoke during regen. I thought that was normal. Is it not?
Old Oct 5, 2010 | 04:27 PM
senix's Avatar
senix
No it is not normal, only times to expect the white smoke would be if your exhaust is not up to temp and you start a regen.
Old Oct 5, 2010 | 06:22 PM
ruschejj's Avatar
ruschejj
When my '08 needed it's 4th radiator at approx. 110K miles I worked a deal with the dealer, they agreed to go 50/50 on it so I paid $600.
bismic
Mar 9, 2022 09:20 AM
smokersteve
2009 - 2014 F150
25
Jan 24, 2022 05:56 PM
cigarxtc
May 12, 2011 02:26 PM
CALINLEIR
Apr 28, 2009 01:47 PM
