Several Problems :(
Old Sep 29, 2010 | 06:24 PM
islander1808's Avatar
islander1808
Several Problems :(
Here we go.
First. I am about 30k into this set of tires and in the inner shoulders are showing some feathering. I had aligned the truck prior to the new tires and the suspension is tight. Could my front leafs be the culprit. Just curious because when I go over a bump at higher speed that is when I notice the road noise due to the feathering.
Second. Is there any way to disable the door ajar light? I can't track down where my wiring has failed and I am tired of looking at it.
Third. Anyone have any luck repairing their overhead trip gauge. Mine quit working and I just hate dropping $170 for a new part.
Thanks for all of the help!
Old Sep 29, 2010 | 07:59 PM
Philbil's Avatar
Philbil
trip computer
As for the trip computer, there are several guys on ebay selling repairs which they guarantee. That is what I am going to try.
Phil
Old Sep 29, 2010 | 08:57 PM
TYZ78F150's Avatar
TYZ78F150
I'm running 265/75/16 terra grapplers and have noticed they are getting louder, but I don't have the wear problems you speak of. They have just over 30k on them.
Old Sep 29, 2010 | 10:53 PM
moto4's Avatar
moto4
I would get the alignment checked again. Also check all front suspension parts unloaded. As to the door ajar light, I would suggest a GOOD dose of silicone spray at each door latch (that is where the switch is) and also at the tailgate doors. It may take a couple of times doing it, mine took twice, but that should last for many years.
Old Sep 30, 2010 | 06:50 AM
katiesdad7's Avatar
katiesdad7
The door ajar light is almost certainly from the rear glass. Just spray it and slam it a few times. Pretty common problem.
Old Sep 30, 2010 | 07:13 AM
71-4R3SONS's Avatar
71-4R3SONS
You say the suspension is tight... But, to me, it sounds like your ball joints might need replacing. A front end alignment with bad ball joints is like drinking decaffeinated coffee or NA beer... worthless.
If your X is past 75K miles, you probably need new ball joints. Mine went around 68K and the same was true for my 99 250SD.
Old Sep 30, 2010 | 07:38 AM
islander1808
Thank you guys for all of the suggestions guys. I am going to pull my lie-o-meter this weekend and send it off for repair.
I am due for a rotation as well on my tires so I'll have them check out the ball joints.
I've tried spraying the latch with WD40 to no avail but I'll give it another whirl and let you all know how it turns out.
dvrjump
Aug 23, 2013 09:49 PM
Joshua Sirchuk
Aug 13, 2013 01:46 PM
lanedecamp
6.7L Power Stroke Diesel
Nov 5, 2012 12:11 AM
imlowr2
15
Jun 12, 2005 11:39 PM
