Corrosion on Alternator
Old Sep 29, 2010 | 04:07 PM
CorpusBragg's Avatar
CorpusBragg
All,
I have a new, spare alternator that I would like to perform preventive maintenance on. Specifically, treat the aluminum and paint it. The alternator installed on my '00 Ex needs the same maintenance.
Anyone know of this being done before?
/r,
Old Sep 29, 2010 | 08:06 PM
perryg114's Avatar
perryg114
You want info on how to rebuild your spare alternator or what?
Perry
Old Sep 29, 2010 | 08:51 PM
howler4x4's Avatar
howler4x4
If you don't know the history of the spare then rebuild it for sure. Wire brush the corrosion.
Won't paint keep the heat in?
Oh, if you are tempted by rebuild kits that boost the output make sure they don't raise the kick-in RPM. Pls don't ask how I know
Old Sep 29, 2010 | 09:01 PM
perryg114's Avatar
perryg114
Usually new bearings and field coil brushes are part of a rebuild. Also the diodes need to be checked if they are built into the unit. To replace the front bearing you usually need a puller to remove the pulley. Diodes and brushes are the things that are going to cause problems. A little surface corrosion is not a big deal. If the bearings are not rough don't mess with them. The alternator or generator as the manual calls it has a built in voltage regulator.
Perry
CaptainMarvel
1997 - 2003 F150
Mar 19, 2015 12:52 PM
joe blow
Sep 7, 2014 10:21 AM
mu2bdriver
General Diesel Discussion
Dec 15, 2013 08:15 PM
DaveNTx
Aug 20, 2013 07:45 PM
CuMinR
6.7L Power Stroke Diesel
Jun 25, 2013 02:05 PM
