Low Battery Issues
But, before replacing anything I believe you should test it.
That being said, if you've concluded that you need an alternator, ignore the hissy fit of the guy who's pissed off because no one is listening to his crap and get the best alternator that you can for the money. I personally would get an OEM one. They're not any more expensive than the others and it's lasted since '05 on your truck so far.
It's true that continual high heat is hard on batteries. But there is no reasonable reason to believe that high heat causes alternators not to output as much, nor will make them fail any quicker. Think about their normal operating environment. It gets pretty damned hot under that hood anyway.
Output vs Temperature:
Operating temperature also affects output - higher temperatures resulting in lower outputs. Heat reduces output, and shortens alternator life.
“Cold” Amps rating is for an ambient air temperature of 77 degrees Fahrenheit (25 C), such as when an engine is first started, and will often be 10 - 25% higher than the hot rating.
“Hot” Amps rating is for an ambient air temperature of 200 deg. Fahrenheit (93 C), such as when an engine has been operating for some time.
[see chart below]
An Alternator Specification should describe the Output (Amps) at specific Rotor Speeds, and Temperatures. This is usually presented on a curve, but here’s an example of 2 Alternators in chart form:
Alternator RPM = Alt. “A” Cold* / Hot* ~~ Alt. “B” Cold / Hot
2000 RPM = (A)51A Cold / 41A Hot ~~ (B) 42A Cold / 31A Hot
2500 = 78/63 ~~ 73/58
3000 = 92/76 ~~ 93/76
3500 = 102/85 ~~ 107/87
4000 = 108/92 ~~ 117/96
4500 = 114/96 ~~ 123/102
5000 = 118/99 ~~ 127/107
5500 = 121/102 ~~ 131/110
6000 = 123/104 ~~ 134/113
6500 = 124/106 ~~ 136/116
Note:
Alternator “A” might be “rated” at 124 Amps, but will rarely achieve anywhere near that output in actual use. The 124A rating is “cold”, at 6500 rotor RPM (perhaps 3250 Engine RPM). Re-charging at anchor, you might realistically expect something on the order of 63A output (about half it’s rating).
Given below are alternator outputs versus temperature and alternator RPM. Note: All alternators are P-type units except the 32 Volt, #4132 model.
<table border="1" cellpadding="3"> <tbody><tr><td align="LEFT">Alternator</td> <td align="LEFT">#4023</td> <td align="LEFT">#4024</td> </tr> <tr><td align="LEFT">RPM</td> <td align="LEFT">Cold/Hot</td> <td align="LEFT">Cold/Hot</td> </tr> <tr><td align="LEFT">2000</td> <td align="LEFT">51/41</td> <td align="LEFT">42/31</td> </tr> <tr><td align="LEFT">2500</td> <td align="LEFT">78/63</td> <td align="LEFT">73/58</td> </tr> <tr><td align="LEFT">3000</td> <td align="LEFT">92/76</td> <td align="LEFT">93/76</td> </tr> <tr><td align="LEFT">3500</td> <td align="LEFT">102/85</td> <td align="LEFT">107/87</td> </tr> <tr><td align="LEFT">4000</td> <td align="LEFT">108/92</td> <td align="LEFT">117/96</td> </tr> <tr><td align="LEFT">4500</td> <td align="LEFT">114/96</td> <td align="LEFT">123/102</td> </tr> <tr><td align="LEFT">5000</td> <td align="LEFT">118/99</td> <td align="LEFT">127/107</td> </tr> <tr><td align="LEFT">5500</td> <td align="LEFT">121/102</td> <td align="LEFT">131/110</td> </tr> <tr><td align="LEFT">6000</td> <td align="LEFT">123/104</td> <td align="LEFT">134/113</td> </tr> <tr><td align="LEFT">6500</td> <td align="LEFT">124/106</td> <td align="LEFT">136/116</td> </tr> </tbody></table>
12 Volt Alternators ...Small Case
<table border="1" cellpadding="3"> <tbody><tr><td align="LEFT">Alternator</td> <td align="LEFT">#4059</td> <td align="LEFT">#4060</td> <td align="LEFT">#4300</td> </tr> <tr><td align="LEFT">RPM</td> <td align="LEFT">Cold/Hot</td> <td align="LEFT">Cold/Hot</td> <td align="LEFT">Cold/Hot</td> </tr> <tr><td align="LEFT">2000</td> <td align="LEFT">98/87</td> <td align="LEFT">65/60</td> <td align="LEFT">20/13</td> </tr> <tr><td align="LEFT">2500</td> <td align="LEFT">122/110</td> <td align="LEFT">114/105</td> <td align="LEFT">75/66</td> </tr> <tr><td align="LEFT">3000</td> <td align="LEFT">134/124</td> <td align="LEFT">146/133</td> <td align="LEFT">160/130</td> </tr> <tr><td align="LEFT">3500</td> <td align="LEFT">144/131</td> <td align="LEFT">165/150</td> <td align="LEFT">210/175</td> </tr> <tr><td align="LEFT">4000</td> <td align="LEFT">150/134</td> <td align="LEFT">175/162</td> <td align="LEFT">240/205</td> </tr> <tr><td align="LEFT">4500</td> <td align="LEFT">154/138</td> <td align="LEFT">184/169</td> <td align="LEFT">260/225</td> </tr> <tr><td align="LEFT">5000</td> <td align="LEFT">156/141</td> <td align="LEFT">189/174</td> <td align="LEFT">275/243</td> </tr> <tr><td align="LEFT">5500</td> <td align="LEFT">158/142</td> <td align="LEFT">194/175</td> <td align="LEFT">285/252</td> </tr> <tr><td align="LEFT">6000</td> <td align="LEFT">159/144</td> <td align="LEFT">197/179</td> <td align="LEFT">294/267</td> </tr> <tr><td align="LEFT">6500</td> <td align="LEFT">160/147</td> <td align="LEFT">199/181</td> <td align="LEFT">310/275</td> </tr> </tbody></table>
12 Volt Alternators ...Large Case
<table border="1" cellpadding="3"> <tbody><tr><td align="LEFT">Alternator</td> <td align="LEFT">#4109</td> <td align="LEFT">#4110</td> <td align="LEFT">#4132</td> </tr> <tr><td align="LEFT">RPM</td> <td align="LEFT">Cold/Hot</td> <td align="LEFT">Cold/Hot</td> <td align="LEFT">Cold/Hot</td> </tr> <tr><td align="LEFT">2000</td> <td align="LEFT">35/33</td> <td align="LEFT">40/36</td> <td align="LEFT">30/27</td> </tr> <tr><td align="LEFT">2500</td> <td align="LEFT">80/67</td> <td align="LEFT">100/90</td> <td align="LEFT">75/67</td> </tr> <tr><td align="LEFT">3000</td> <td align="LEFT">100/76</td> <td align="LEFT">125/112</td> <td align="LEFT">94/84</td> </tr> <tr><td align="LEFT">3500</td> <td align="LEFT">113/99</td> <td align="LEFT">145/130</td> <td align="LEFT">109/98</td> </tr> <tr><td align="LEFT">4000</td> <td align="LEFT">119/107</td> <td align="LEFT">158/142</td> <td align="LEFT">118/106</td> </tr> <tr><td align="LEFT">4500</td> <td align="LEFT">123/111</td> <td align="LEFT">170/153</td> <td align="LEFT">127/115</td> </tr> <tr><td align="LEFT">5000</td> <td align="LEFT">126/114</td> <td align="LEFT">175/157</td> <td align="LEFT">131/118</td> </tr> <tr><td align="LEFT">5500</td> <td align="LEFT">128/117</td> <td align="LEFT">178/160</td> <td align="LEFT">133/120</td> </tr> <tr><td align="LEFT">6000</td> <td align="LEFT">130/119</td> <td align="LEFT">180/162</td> <td align="LEFT">135/121</td> </tr> <tr><td align="LEFT">6500</td> <td align="LEFT">135/120</td> <td align="LEFT">181/163</td> <td align="LEFT">136/122</td> </tr> </tbody></table>
24 and 32 Volt Alternators ...Large Case
How good are Ample Alternators? Compare the output current given above to the outputs of other brands at the same alternator RPM and at the same temperature. You'll discover that Ample Alternators put out more Amps at every point! Alternator RPM is given, not engine RPM. Engine RPM is always less ... it depends on the pulley ratios. A Yanmar engine with a 5.4 inch, (132 mm), pulley running at 1200 RPM will spin an alternator with a 2.6 inch, (66 mm), pulley at 2500 RPM. In the rating charts the cold Amps rating is for an ambient air temperature of
Fahrenheit, (
C). The hot Amps rating is for an ambient air temperature of
Fahrenheit, (
C). Typical operating temperatures are much less ...expect more than the hot ratinEvery automotive grade / mass market alternator manufacturer acknowledge that higher temperatures will result in lower output.
Tell me where you get your alternators and where you find the science and facts to back up your statements.
dchamberline:
You were caught posting false information with respect to the voltage test, misleading the OP into believing there is a problem with the voltage when in fact, it test within spec.
Now you claim that " no reasonable reason to believe that high heat causes alternators not to output as much".
The information is factually false.
Stop posting false information on this forum.
I agree with George, the thread will stay closed. In the future, think about what you post.
