EOT and ECT???
Old Sep 29, 2010 | 01:46 PM
Speedjester's Avatar
Speedjester
EOT and ECT???
Well installed my Scan gauge II the other day and took a nice long ride...400+ miles.. It was cooler than usual outside around 64-65*F... Noticed that the ECT was around 173*F and the EOT was about 180-184*F at around 65-70 MPH... But when I accelerated to lets say 80-85 for about 30 miles the oil temp really didnt change(180 -184*F) but the ECT when up to around 180-184*F... I find it starnge that when the truck is worked the gap between eot and ect drops to almost 4*F but when just cruising around it has such a large fluctuation??? Any thoughts..
Is there a bypass that keeps the coolant from cooling the oil to much during cold operation.. Thanks in advance
Old Sep 29, 2010 | 01:56 PM
amgpro2's Avatar
amgpro2
Mine is doing the same thing when it is cooler outside. @75F got 184-190 ECT and EOT was steady @208. Then yesterday during the day it was 100F and the EOT was 195-197 and EOT was steady at 199 to 200. WTF? EOT was actually cooler when its hotter outside. This moring it was 73F and my ECT was 184 and EOT was 202. I got a recommendation in another thread to change the t-stat.
Old Sep 29, 2010 | 04:26 PM
Speedjester
Can't see how a stuck t stat would cause these symptoms...
Old Sep 29, 2010 | 04:38 PM
amgpro2's Avatar
amgpro2
I agree. I also read in another thread that another scangauge use had switched the programing to a pre 04 sensor code on the scangauge cause his readings were off. He did not use the code on the website. moebdick posted these settings.
TXD: 07E0221310
RXF: 046205130610
RXD: 3010
MTH: 000901F4FFD8
NAM: EOT
I use xgauge ver 3.15. What are you using?
Old Sep 29, 2010 | 04:47 PM
Speedjester
Not sure but believe vet 3:17
Old Sep 29, 2010 | 05:36 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
ECT consistently under 190 means the t-stat is opening early or sticking open and not letting the coolant get up to 190*
Could be when the t-stat is stuck open the convection is screwy and flow is inconsistent. The coolant throught the oil cooler isn't flowing as fast, meaning hotter coolant hangs around longer, not drawing off as much heat, and increasing EOT.
Old Sep 29, 2010 | 07:30 PM
Speedjester
I understand what your saying but how does it
Explain that it seems to cool better the hotter it gets....thought it might have been like the oil cooler in my vette.... that bypassed unrolled the engine reaches operating temp...
Old Sep 29, 2010 | 08:11 PM
gearloose1's Avatar
gearloose1
I had a stuck thermostat --- and it opened and stuck causing the ECT to get far too cold on the highway.
However, after a bit of exercising ( the car sat for a long time), the stickiness resolved itself.
Old Sep 30, 2010 | 08:01 AM
Speedjester
Anymore thoughts and opinions???
Old Sep 30, 2010 | 08:21 AM
bismic's Avatar
bismic
The oil is heated by energy created from friction. This doesn't increase dramatically from 70 to 85 mph. The heat from combustion does increase quickly (which heats the coolant more quickly than the oil will be heated). Also, the oil temps always "lag" the coolant temps, so you will always see some of what you describe. Remember 4 and 1/2 gallons of oil takes awhile to heat up.
Old Sep 30, 2010 | 09:57 AM
Speedjester
So you would say that its normal to have a wide 10 to 12* difference between eot and extra just tooling around but under load the margin would drop to 4 or 6*...I do remembers reading somewhere that in order to get accurate rot and extra spread the ect should be above 189*... is this correct...
Old Sep 30, 2010 | 10:05 AM
gearloose1's Avatar
gearloose1
Part of the issue is where the sensors are and what reading they are getting.
See this thread:
https://www.ford-trucks.com/forums/9...hing-else.html
Oil temp sensor beside the filter mean the oil has already "cooled" by the sump, and heat is also lost via the pickup, pump, and pipe before it gets up to the oil filter / cooler.
If you measured oil temperature at spots known to be "hot" you will get different readings.
Old Sep 30, 2010 | 11:01 AM
bismic's Avatar
bismic
The general effect you describe is fairly normal. Operating temps much below 190 when the vehicle is fully warm is not normal (190 degree thermostat).
