Crossmember mod
Old Sep 29, 2010 | 12:59 PM
wreckinball's Avatar
wreckinball
Crossmember mod
Well i am going to go through with the crossmember modification. The engineering shop here in town does them often and makes them where they bolt in with grade 8 hardware. Not one issue reported and their vehicle that they tried it on three years ago still works perfect. No alignment issues, no wobble, nothing. it is a F450 4x4 and it is their all around truck. plows snow, hauls parts, cars, trucks, etc etc. I am no longer worried about it because i know for a fact that i will never be able to put my truck through that much stress. Total is about 4 hours labor plus parts and comes to right about 400. Ford quoted me 19hrs and the other diesel specialist in town quoted 25 hours. Both are about 100 an hour, ford comes in at 95, and sometimes i can get them to drop it to 75 an hour. I gave them a lot of business so i guess i earned it hahaha. so the diesel specialist, is 2500 for labor alone, and ford at cheapest is about 1500 and normally around 1900. This will enable me to do a oil pan swap or reseal or any work under there in a fraction of the time. aside from oil drain time, the removal and replacement of the crossmember takes them about 30 minutes. Is it worth it, how can i say no?
Old Sep 29, 2010 | 01:14 PM
LCAM-01XA's Avatar
LCAM-01XA
What exactly do they do - drill out the old rivets, and install bolts in their place?
Old Sep 29, 2010 | 07:12 PM
greywynd's Avatar
greywynd
What cross memeber are you talking about and what does the mod give for advantages?
Old Sep 29, 2010 | 08:43 PM
rodneywar's Avatar
rodneywar
he is talking about the crossmember that is under the oil pan
the mod makes it easier to remove the oil pan without pulling the motor
Old Sep 29, 2010 | 10:48 PM
wreckinball
well it seems that they will cut the xmember before the engine mounts, drill holes and drop it out. while out it gets the double sided tabs that mate to the frame side and it all goes together like clockwork. Cant wait for the drop off next week. Ill get the valley pan fixed this weekend, gotta love felpro.
Old Sep 30, 2010 | 05:09 AM
fonefiddy's Avatar
fonefiddy
So Your basically gonna cut the truck in half to remove the oil pan???
Huh... seems to Me, it'd be cheaper, and easier to just remove the engine. DIY!
I've heard of Guys lifting the engine, unbolting the oil pump, and removing the oil pan. Seems to work.
Old Sep 30, 2010 | 09:03 AM
idiguy's Avatar
idiguy
Thats exactly what i did to mine fiddy, bought a brand new oil pan and had it powdercoated black, i live in PA where raod salt loves to munch on metal
Old Sep 30, 2010 | 09:08 AM
wreckinball
this fix will be a one time fix. From then on it will cost nothing to remove the oil pan. LEts say i am driving down the road and see my oil pressure drop to zero, oil pump died. With this mod i could do it roadside. If i go buy a decent hoist, again, i am looking at 200 minimum for one i trust, then i have to loosen the engine mount hardware(have to get down there regardless) then i have to worry about barely being able to squeak the oil pan out, possibly jacking up the new seal i have laid on the pan while putting it back in.....yeah i dont see it. Cutting the truck in half, not really. The engine will hold it in place and together if the crossmember gets removed so it isnt as scary as you might think. haha. Either way i am going to do this, a diy project like removing an engine is not something i really ever have time for. This can be done in a few minutes once the engineering shop does their work. The longest part would be waiting for the drip down. Some of our trucks arent even worth what it costs to get the engine pulled and replaced. I paid that labor once when i did the re and re for the new(er) engine. I just dont have an entire weekend to devote to an engine pull.
Old Sep 30, 2010 | 09:11 AM
wreckinball
Yep when the oil pan is off i will sand blast the pan to see if there are weak points and if not i will prime and por-15. Dont want to ever deal with this thing again hahaha.
Old Sep 30, 2010 | 09:17 AM
idiguy's Avatar
idiguy
Yeah i hear that, when i had my oil pan i changed the oil pump so i really dont have to do that again, that went out the door since im doin this PSD swap lol
Old Sep 30, 2010 | 10:00 AM
wreckinball
grabbing an oil pump this weekend so i wont have to deal with that either, although it isnt a big deal anymore to remove it, i still dont want to "have" to do it again haha. good luck with that swap, when mine dies, i might go the 6bt route but who knows. We may wind up in the UK next so frank cant go.....
Old Sep 30, 2010 | 10:44 AM
fonefiddy's Avatar
fonefiddy
In 10 years of reading these message boards, I've heard of 1 oil pump failing. And that one was iffy. I think the Guy modified the rear header
With most of Our rigs being high mileage,and that kind of failure rate, I doubt there's anything wrong with the OEM pump.
Old Sep 30, 2010 | 11:20 AM
wreckinball
Yeah your probably right. But if I do replace it, it'll be one less thing I'll have worry about. Know what I mean?
Old Sep 30, 2010 | 11:41 AM
swooshcmk's Avatar
swooshcmk
I dunno... based on the quality of some of the new parts I've seen in the last year or two I think I'd rather keep my old one
SuperDuty93
15
Oct 12, 2023 02:11 PM
jjarboe01
15
Nov 8, 2021 02:48 PM
pdxranger
May 27, 2017 10:48 AM
Mavrett
May 5, 2016 11:54 AM
Mavrett
General Diesel Discussion
May 4, 2016 06:43 PM
