Speed Bleeder's
Old Sep 29, 2010 | 05:21 AM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Speed Bleeder's
Has anyone used speed bleeders? Do you need to coat the threads with pipe dope? How do they work? Thx!
Mike
_________
2002 F-350
Old Sep 29, 2010 | 07:28 AM
riverrat41's Avatar
riverrat41
I assume you are talking about brake bleeders?I do not have any but I have seen them used.The ones we used worked but we were not confident in them so we ended up doing it the old fashion way beings there was two of us.
Old Sep 29, 2010 | 08:24 AM
DieselCamper01's Avatar
DieselCamper01
I have considered using them but always wondered if the road salt would be an issue in MN so I have never pulled the trigger myself. Sorry, I don't know anybody personally that has used them.
Old Sep 29, 2010 | 10:54 AM
Calli's Avatar
Calli
Mike, I have and use. No sealer needed. Just replace loosen and pump. They have check valve to prevent drawing air back into system. One at a time. Start rt.rear, left rear, rt front, left front . Easy, even I can do.
If I remember correctly, there is compound on threads??
Old Sep 29, 2010 | 11:04 AM
clintbonnie's Avatar
clintbonnie
Speed Bleeders....I have have them on truck and they work great... If worried about corrosion, get the stainless steel ones.. a little more money but worth it.. No thread sealant needed..
http://speedbleeder.zoovy.com/
Old Sep 29, 2010 | 04:03 PM
Mike F250's Avatar
Mike F250
I just put a few on my motorcycle. They did have a sealant on the threads already
Whitey Ford
15
Jun 3, 2012 04:38 PM
MoyockPowerstroke
Jun 14, 2009 08:51 PM
thedaddycat
Dec 6, 2007 09:01 AM
tony_cabral
17
Oct 3, 2005 08:15 AM
