Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Would this compressor be enough?
Old Sep 28, 2010 | 11:27 PM
grandads76's Avatar
grandads76
I need a compressor for air tools (impact wrench, sander, grinder, etc) and would like to look at some sanding/blasting, maybe even priming (but no painting). I am looking at this one, is it over kill or is it not enough?
Campbell Hausfeld 80-Gallon Air Compressor
Item #: 292655 | Model #: DP5810-Q
* Choose air power for versatility, value and power - this one air compressor powers all the tools you need for daily automotive shop air jobs
* Operates over 20 air tools for automotive spray painting, sanding work, cutting sheet metal, grinding, rotating tires, repairing engines and exhaust systems, sharpening blades, sanding wood, inflating car tires, cleaning workbench area
* Longer life pump - durable and reliable cast iron, four cylinder oil-lubricated pump designed for up to 10000 hours of extended life (Based on B-10 bearing rating)
* Easy access tank drain located on side of tank - no need to reach down under the tank
* Durable 80 gallon ASME code tank for safe, reliable operation
* Powerful 208 - 230 volt, single phase 5 HP motor with overload protection (No special motor starter required)
* 140 max PSI so you can operate a wider range of tools and maintain longer run time
* 16 SCFM @ 90 PSI - easily runs high demand air tools such as sanders and grinders
* 3 year limited warranty
Old Sep 28, 2010 | 11:34 PM
fixnair's Avatar
fixnair
It should work for you well except when you are grinding or sandblasting. It does not have enough capacity at16 SCFM to operate a sandblaster much longer than a few seconds or a die grinder very long.
Old Sep 28, 2010 | 11:41 PM
ford390gashog's Avatar
ford390gashog
I have one they are okay. But CH is going overseas for way to many of their parts now. The pump is made in india and the motor is made in brazil the tank is us made but notice the safety rating on the tank that was what shocked me only rated for 200 psi at 450 degrees not much margin for error. Compared to my 1997 quincy which is rated at 300 psi at 550 degrees. Have you considered eatoncompressor.com they have very could service and stand behind what they build and their units are very quiet.
Old Sep 29, 2010 | 02:44 PM
ssbenn11's Avatar
ssbenn11
I have an Ingersoll Rand and I love it. They have all different types too, even used. So you should be able to find one good for grinding or sandblasting.
Check out the Website Here: IR Air Compressors
Old Sep 30, 2010 | 11:59 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
I have an 80 gal. 7.5 hp Craftsman about 12 years old. I paid under a grand for it and it has done everything I could ask including driving 5" nails when my pole barn contractor burned out his portable compressor.
Old Sep 30, 2010 | 06:31 PM
tjc transport's Avatar
tjc transport
i ain't rite
that compressor will do everything you want except for sand blasting.
for that i borrow a 175CFM compressor.
Old Sep 30, 2010 | 06:49 PM
grandads76's Avatar
grandads76
I've been doing some more looking around, any yays or nays for the Kobalt ones at Lowes? They have a similar one for about the same price.
Shane
Old Oct 1, 2010 | 06:20 AM
tjc transport
i ain't rite
the kobalt compressors are made by C.H.
Old Oct 17, 2010 | 03:40 PM
mmpg33's Avatar
mmpg33
Agree 100% Not a fan of CH
daveengelson
Garage & Workshop
21
Dec 6, 2015 06:49 PM
Famousamos
Paint & Bodywork
Jan 14, 2012 05:50 AM
66 twin i
Garage & Workshop
Sep 11, 2009 12:35 AM
SLE
Garage & Workshop
17
Feb 16, 2006 02:25 PM
waandrews
Garage & Workshop
Feb 19, 2003 05:40 PM
