Ok so I have been trying to get my grill off and I can't get the damn clips out is there a trick to it. It looks pretty strait foreword but I have been tryin for a wile
Ya I removed the screws and tried pulling and saw the metal clips in the bottom I just didn't want to break it I guess I will just pull a little harder. The only screws are in the top right I didn't see any others wasn't sure if there are some hidden ones or something
Pop has you covered. Just a little pressure with the flat blade screwdriver on each clip and pull. Be careful to not pull too hard when the clip is still locked, you will break off the plastic. I watched a buddy do this.
Do one clip at a time, push up with the screwdriver on clip and pull right above the area and the grill will pop. Repeat for all the clips. It's un-nerving at first but you get the hang of it.
