Switchable DP Tuner w/ Insight?
Old Sep 28, 2010 | 08:24 PM
N4TECguy's Avatar
N4TECguy
Hi all, I'm new to the whole diesel scene. Just got a '00 F-250 4x2 CC SB Lariat, 7.3/4R100. Sorry if this has been covered, I searched Google but didn't find a good answer. I'm looking to run a DP Economy tune and also have a Insight CS to monitor EGT/Boost/etc. I run the Insight and still be able to have switch on the fly, maybe with a OBDII splitter? Also, what is the difference between the Econo and Econo Mountain tunes?
Old Sep 28, 2010 | 09:28 PM
Duck Hunter81's Avatar
Duck Hunter81
You should be able to use both without a problem. Like you said, the Insight plugs into the ODBII port and the DP tuner connects to the PCM. The one problem with the Insight is that it isn't as accurate as regular guages because they use factory sensors (except EGT probe).
Also the Econo and Mountain Econo are different.
Old Sep 28, 2010 | 09:49 PM
N4TECguy's Avatar
N4TECguy
Oops, didn't know the Insight plugged into the PCM. I only heard about the 6.4 tuners and assumed the 7.3 was the same way. What do you guys use to get the "protective coating" off the PCM connector before attaching the chip?
Also what is the difference between the two tunes specifically?
Old Sep 29, 2010 | 07:38 AM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
The 7.3l PCM has a J3 port for chip modules to easily be inserted. The 6.4l's don't. All PCM programming has to be done through the OBDII on 6.0's and 6.4's. 7.3's you can program the PCM both ways.
Are doing a Flashed PCM with one tune or getting a multi position chip?
Before touching the PCM to install a chip you need to know the proper procedure to cleaning the J3 port contacts.
Chip Install instructions
The insight plugs up to the OBDII port and is used for a gauge. The chip plugs into the J3 port of the PCM. You can use both together, but you cannot use the Insight to control our chip for switching.
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
Old Sep 29, 2010 | 08:06 AM
N4TECguy's Avatar
N4TECguy
Thanks for the response, I would do a multi-position chip
Old Sep 29, 2010 | 12:18 PM
KH85's Avatar
KH85
Do you already have this Insight SC monitor? If you dont then like staed above I would look into getting real guages so you know exactly whats goin on under the hood.
Old Sep 29, 2010 | 01:04 PM
BillyBob69's Avatar
BillyBob69
The diff between mountain and econo is going to mainly be shift points. Both up and down. You will notice the diff once you are out driving around.
Old Sep 29, 2010 | 01:13 PM
4inchlovin's Avatar
4inchlovin
I do not know about the insight monitor, However I have the Aerforce interceptor gauges that plug into the obd11 and when I put my Dp in a tune my boost reads in-accurately. It will actually read negative boost at idle, lol. which is not possible because that would be "vacuum". Perhaps DP can chime in on why this happens. I would guess its because the tuner is fooling that map sensor and that is where the gauges are reading boost from.
Old Sep 29, 2010 | 07:09 PM
N4TECguy's Avatar
N4TECguy
Any particular reason for this? I did consider both alternatives, I already have a ScanGauge that I usually use in another car but transferred to this one to get an idea of whats going on. I think the EOT and tranny temps are accurate. The boost wouldn't be a big deal to me, as long as it's precise it doesn't have to be accurate (ie. if everyday it usually runs 17PSI and then today it's running 20 then I'd be concerned, even if in reality it's 15/18). The EGT should be accurate since it comes with its own probe. Anything else that is really important that wouldn't be accurate/precise on the OBDII signal?
Kennetho
Electrical Systems/Wiring
May 14, 2012 07:05 AM
egreath
26
Mar 18, 2012 07:05 PM
hdman6
15
Feb 15, 2007 02:54 PM
blue02gt
17
Feb 6, 2007 11:30 PM
